I'm finally finished.
Old Jan 11, 2003 | 06:48 PM
bhaas's Avatar
And it's pouring down and rain. WTF??? I want to go for a test thrash. Here are a couple of pics. I jetted the secondaries on my carb 3 stages rich .110 and left the primaries stock for now. Will probably end up richening the primaries up to. Need to go test drive it. If it's not raining tomorrow, even for a few minutes and it's a bit dry, I'm driving it.
Brad...
Old Jan 11, 2003 | 07:22 PM
MdFormula350's Avatar
:hail: :hail: :hail: :hail: :hail:
Old Jan 11, 2003 | 08:31 PM
TheMagicFormula's Avatar
That is a great looking setup. Where did you get that rubber tubing that runs from the turbos to the carb? Some of that would make my tt project a lot easier. Looks better than PVC pipe, too
Again, that engine looks simply awesome :hail:
Old Jan 11, 2003 | 10:40 PM
StocRoc's Avatar
very nice man, let us now how it runs
Old Jan 11, 2003 | 10:50 PM
bhaas's Avatar
Thanks guys. I'll definately let you all know how it runs. Hopefully soon. I got that rubber hose from an industrial supply place. (Williams Oil Filter) here in Tacoma. It was almost $50 for 5 feet of it. It is tough and has wire going through it. Worked out pretty good. I also used T bolt hose clamps. They're much stronger and hold tighter that the regular hose clamps.
Brad...
Old Jan 11, 2003 | 11:38 PM
87transam5.7tpi's Avatar
very very good looking!! have fun and be safe w/ that bad boy:hail: :hail:
Crazy2.8V6Man's Avatar
Very nice lookin setup you have. Im takin it your not 17 and still go to highscool. The first think i do when I get outta highschool is a tt setup.
Old Jan 12, 2003 | 01:55 AM
maroon91rs's Avatar
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
Do you have a BOV on those bad boys?I dont see one in the pic anywhere.Or are you able to run without one for some reason?
Old Jan 12, 2003 | 09:02 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
It's an auto, so a BOV isn't really the most needed thing.
Old Jan 12, 2003 | 09:17 AM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
tubing
I know we sell tubing like that at napa. It looks like the tube that is used to run to the gas tank.
Are you afraid you wil loose presssure by using rubber tubing?
Old Jan 12, 2003 | 10:25 AM
bhaas's Avatar
I have Deltagates on both ends of the headers. No BOV no room for one. That hose isn't like that hose at NAPA. It's a lot stronger and has wires running through it and it's very strong. I shouldn't lose any pressure using it. I'll find out if it ever stops raining here.
Brad...
Old Jan 12, 2003 | 10:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Looks nice...
What kinda boost you runnig? etc.. Turbo size?
Old Jan 12, 2003 | 11:22 AM
bhaas's Avatar
The turbos are T3's 63X60 and my wastegates are set at 9psi. I should go to 5 psi but I'm too lazy.
Brad...
Old Jan 12, 2003 | 11:51 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
That tubing looks like stuff I've seen at a power plant for temporary air hose (110 psi). Probably overkill for a boosted application since the clamps are the most important part. I doubt it will expand at all though, a good thing.
Old Jan 12, 2003 | 01:09 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
WOOT WOOT
Old Jan 12, 2003 | 02:00 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Nice Nice job....... Get some 114 octane race gas.
Might want to use a set of detonation ears while testing.
go to www.autospeed.com and search the free tech articles on how to build a DIY set of detonation head phones from a
simple radio shack listening amplifier. It's easy to build.
Makes the best detonation sensor going..... your ears...
Old Jan 12, 2003 | 02:18 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
You rule dude! Let us know how the test flight goes.
:hail: Turbos:hail:
Old Jan 12, 2003 | 10:42 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Just an idea for you. See that area on either side of the carb bonnet where there isn't anything in the way? You could easily weld a flange onto one side of that bonnet (or even on top of the bonnet if you have enough clearance in the cowl scoop) and mount a BOV to vent to the atmosphere. Might be worth it to prolong the life of your turbos, plus they sound cool.
Old Jan 12, 2003 | 11:17 PM
bhaas's Avatar
I'd love to put one on but I paid $170 for the bonnet, it's aluminum and nice and shiny. I'd hate to cut a hole in it. I do have wastegates though, one for each turbo. That's gonna have to do it for now.
Brad...
Old Jan 12, 2003 | 11:23 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
I know your pretty far away, but please don't point that thing towards my house when you floor it for the first time!!!:hail:
Old Jan 12, 2003 | 11:31 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
yeah dont point it at me either man.
Old Jan 13, 2003 | 05:22 AM
ta84-355's Avatar
Car: Trans Am -84
Engine: 355, Twin Turbo
Axle/Gears: 3.73 open
Nice work. I'd love to see some more pictures on the installed downpipe on the drivers side. I've been banging my head to the wall trying to figure out a way of doing a nice clean setup. My JY Turbo project is still in the "which route to go" phase - no fabrication has been done yet.
/Anders
http://www.itv.se/~a1003/turbo
Old Jan 13, 2003 | 07:06 AM
BOTLFED's Avatar
Right on Bhass, congrats!
Can't wait to hear the results and I hope to *** you richened your carb enough!!
I'm about a week or two behind you... good luck!!!
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
sandman92084
Sep 12, 2015 10:27 PM
