anyone polished their N2O bottle?
Old Jan 16, 2003 | 04:50 PM
Kandied91z's Avatar
mines painted and i'd like to polish it...is it possible?
Old Jan 16, 2003 | 06:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
like this see this site for polishing tell him tom from outlaw sent you.
Old Jan 17, 2003 | 12:58 AM
Kandied91z's Avatar
was that a normal painted bottle.........so it's possible???
that would be great if it were!
Old Jan 17, 2003 | 01:42 AM
83 Crossfire TA's Avatar
Have you ever picked one up empty... they're probably over 1/2" thick.
Oh, and just about all of them are made by the same company and then just painted and have a valve added by the N2O co that you buy them from, so they should all polish up about the same
Old Jan 17, 2003 | 07:23 AM
BOTLFED's Avatar
That's pretty wicked, wish I had the patience to do that to mine.
Cheers,
Old Jan 17, 2003 | 10:17 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
actually they are less than or around a .250" thickness depending on what part of the bottle. If you look at the parts of that dumb guys exploded bottle from his r i c e r that has posted on over and over again. I have seen a "cutaway" display from NOS and NX to see for myself. the bottle shown was one we sold unpainted but it is the same brand used by all the nitrous manufacturers. we we used to sell the unfinished 10#'s for $159 and the 15#'s for $179. It cost about that much nearly to put them together. as for a powdercoated bottle (most manufacturers dont simply paint them) the paint/powdercoating would just be removed first with a fine media blast. the fine media part is important because simple sand blasting could result in retempering the surface of the bottle with its miniature hammerlike properties of sandblasting the soft aluminum. contact that guy in that post with the picture and he can take care of you CHEAP!
Old Jan 17, 2003 | 01:54 PM
Are you sure about the powerdercoating? I've seen a couple of different manufacturor's bottles just flake off like cheap paint (including the NX 15# in my garge) does when you paint aluminum with no primer. The second reason that I doubt that they're powdercoated is that the 400* that they use to cure powdercoat is also the same temp that most aluminum aneals at (becomes super soft, think about this the next time someone powdercoats aluminum wheels... it's the reason why high end wheel manufacturors will not sell powdercoated wheels and void warrenty's for it). Also the reason why using a propane torch to heat a bottle is really stupid.
Any kind of media blasting would work harden the outer shell of the bottle which would make it prone to cracking with an impact. I'd just use some aircraft stripper, it will rip most finishes off quickly.
I'd imagine that they'd have a fairly decent finish underneith that, most of the work in getting it polished would be cleaning up any dings and the formed area on the top aroudn the valve... I bet you could do one in a few hours...
Old Jan 17, 2003 | 01:55 PM
Hum... how do you ship a N2O bottle?
Old Jan 17, 2003 | 02:53 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Put it in a box, and put the persons address on it, pay for shipping, usually UPS, fedex, or post office, and it should arrive to the addressees place shortly.
Old Jan 17, 2003 | 03:16 PM
I'm postive that UPS will not just take an N2O bottle if they know that it's there, even if you assure them that it is empty. I've tried to ship car parts before and they've always wanted me to fill out another form specifying what 'car parts' meant, and even made me open a box with a carb in it to prove that it hasn't had fuel run through it (basically smell).
Fed Ex seems more willing to go out of their way to hep you shift what in most people's mind is 'wierd' stuff, and I still have a hard time believing that you can just walk in and ship a pressure vessle...
Old Jan 17, 2003 | 03:17 PM
87transam5.7tpi's Avatar
just empty it and leave the valve open. then ship it, you'll know its safe and I bet they won't ever find out. not that I'm saying go against rules, but if the valve is open and its empty there is not chance of harm to anybody right?
Old Jan 18, 2003 | 08:40 PM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
Here is mine...
Took about 15hrs to get it polished.. well worth the effort..
Old Jan 18, 2003 | 09:08 PM
Kandied91z's Avatar
could you give me some detail as to how you did that....
i was thinking about using some sort of stripper for the paint and then just going over it by hand like normal polishing?
what would i need to do?
also....what brackets are you using? those look nice!
Old Jan 18, 2003 | 09:34 PM
Originally posted by Skweezn87
Here is mine...
Nice polished parts, but it raises one question. What do you think the chances are that if your car does catch fire you'll be standing outside it with the trunk open? You might want to reconsider that mounting location for the extinguisher...
Old Jan 20, 2003 | 01:43 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
UPS never hassled us about whether they were empty or not they just wanted us to say it wasnt and that we knew it was not allowed. all of them maynot be powdercoated I think NOS does but it will come off too.
Old Jan 20, 2003 | 02:03 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
heres another
Old Jan 21, 2003 | 09:35 AM
Skweezn87's Avatar
Engine: 427 SBC
83 Crossfire TA
All for looks ...
Old Jan 21, 2003 | 10:17 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
hay give the guy a brake he could be like me and have 3 of them
Old Jan 23, 2003 | 04:51 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
LOL I just got it.....
Old Jan 23, 2003 | 05:59 PM
Kandied91z's Avatar
alot of car shows make you have them....deduct alot of points for those stupid things.
i've got mine up in front so i can reach it quick, but for shows i put it in the back as well.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
dusterbd
Sep 29, 2015 08:40 AM
