single turbo
Old Jan 21, 2003 | 08:29 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
single turbo
hey guys,when you run a single turbo do you just run it off of one side of the engine or do you somehow have to use both sides?
Old Jan 21, 2003 | 09:10 PM
Guido's Avatar
Car: 2000 Trans Am
Somehow have to use both sides.
Old Jan 21, 2003 | 09:12 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
LOL
Running it off of one side would create some unwanted side effects.
Old Jan 22, 2003 | 02:01 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Acutally GM has an engine built like that.
It is a SAAB 3.0L (180 CUI) V6 released in 1997. It is still sold.
http://www.saabnet.com/tsn/press/121597.html
Technical data for 2003:
http://media.gm.com/division/2003_pr...ar_Engines.pdf
3.0T V6 TURBO
Displacement: 2962cc
Compression ratio: 9.5:1
Valve configuration: DOHC, 4 valves per cylinder
Bore x stroke: 86.00 x 85.00mm
Fuel system: multi-port injection
Horsepower: 200 @ 5000 rpm
Torque (lb-ft): 229 (311 Nm) @ 2500-4000 rpm
Aspiration: single-bank watercooled turbocharger with intercooler
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
