bhass ->>
Old Jan 25, 2003 | 01:21 PM
Dan W's Avatar
bhaas ->>
Brad,
I was wondering if you would mind taking a picture of your drivers side down pipe where it goes between the log and steering collum.
Thanks,
Dan
Old Jan 25, 2003 | 02:19 PM
bhaas's Avatar
The name is bhAAs. Thank you. Here's a pic.
Brad HAAS
Old Jan 25, 2003 | 03:07 PM
Dan W's Avatar
I'm so sorry bro, I saw someone do that before to ya... not intentional. Thanks for the pic.
Old Jan 25, 2003 | 05:29 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
say BHAAS,
What kinda welder(s) / rods / voltage / amps etc... did you use to fabricate what you have there?
And how did you check to see if your welds were air tight?
and isnt that heat wrap going to warp the headers?
Old Jan 25, 2003 | 05:40 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
what heat rap???
Old Jan 25, 2003 | 11:13 PM
bhaas's Avatar
I'm using a mig with .035 wire and it's on pretty hot. They might warp. I don't care. Kinda want to make a different set of headers anyway. I didn't check for air tightness. They don't seem to leak. Not that I've noticed anyway. Here is a pic of my welder. It's cheap but works killer. Used it today to weld in a new support for a friends engine hoist. I'm also using 75/25 Argon mix.
Brad...
bEtUr4dRustang
Mar 12, 2003 10:44 AM
bEtUr4dRustang
Jan 20, 2003 11:10 PM
