Is a bypass valve needed when....
Old Feb 17, 2003 | 08:41 PM
rooster433's Avatar
IS a bypass valve needed when the throttle body is before the blower?? you would think as soon as the thorttle shuts blower is not able to get anymore air..
Old Feb 17, 2003 | 11:37 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont know about that but I have heard of a phenomenon that causes the TB blade or blades to stay open from airflow when used before the blower/turbo, anyone else?
Old Feb 18, 2003 | 12:52 AM
lane's Avatar
My friend made a custom setup with the throttle body before the charger and never had a problem running without a bypass valve. It will depend on the type of charger you use. He was using a roots style with cog belt. Centrifugals may give you problems because they function differently, but I know the setup was fine with the roots style. hth
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
