boost controllers?
Old Feb 19, 2003 | 03:39 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
boost controllers?
just wondering what you guys like to use for boost control?
was reading my turbo & high tech performance mag today and it brought a lot of them to my attention
Old Feb 19, 2003 | 04:11 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
I used the stock WG, it's pretty good until you get up there with the boost anything over 20 and I get some spikes. It spiked 20 28psi before the HG went. Most likely the cause. The HG on these motors is the weak link and the savior. If you stud the head the gasket won't blow and you'll be shoveling your crank off the track....
Old Feb 20, 2003 | 08:39 AM
WickedTwinTurbo's Avatar
I use two Turbonetics deltgates, one for each turbo on my TA with regulator in side the car to control them + or - boost. I use one Racegate from Turbonetics on my GN with a regulator inside the car aslo for + or - boost control. and stock puck style wastegate setup on my Typhoon, I also have the regulator inside the vehicle to bleed air, only to increase boost.
Prasad
Old Feb 20, 2003 | 10:05 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
right now I am limited to the stock style wastegate for my rx7 except I think I might bore it out and use a honda valve in there for the flapper door... not sure though.
but really curious as far as electronic boost control. which has fast responce time which would also help spool time by holding the wastegate closed all the way till I hit the right boost
grr.... too much to learn this time so I get it right
Old Feb 20, 2003 | 11:53 AM
BOTLFED's Avatar
rx7speed: Here are a couple of neat Boost Controller links..
http://www.gusmahon.org/html/boostcontrol.htm
http://www.gusmahon.org/html/boost%20control.htm
WickedTwinTurbo: You have a new email awaiting your reply.. =)
Cheers,
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
