what is a B&M miny blower
Old Feb 26, 2003 | 05:20 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
i seen a pic a wile back with a thirdgen that had a B&M mini blower on that looked real cool and practical ware can i get one and how much do they cost. thankx for all the help guys
Old Feb 26, 2003 | 07:35 PM
z28monster's Avatar
Car: 86 IROC-Z
any one
has any one herd of a B&M miny blower i am realy intrested in getting one.
Old Feb 27, 2003 | 02:41 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
probably kingtal0n and the weiand 142 he had...
Old Feb 27, 2003 | 10:26 AM
z28monster's Avatar
Car: 86 IROC-Z
can u get a pic of it
can u help me ouit and get some pix of it and pricing and availability of it please.
Old Feb 27, 2003 | 11:26 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
http://www.holley.com/HiOctn/ProdLin...-144_CSBP.html holly bought B&M
Old Feb 27, 2003 | 02:27 PM
z28monster's Avatar
Car: 86 IROC-Z
thank u thats it
thanx guys thats what i was looking for >
Old Feb 27, 2003 | 02:47 PM
z28monster's Avatar
Car: 86 IROC-Z
only one problem
i called the 1 800 number on the site to get a dealer near me and teh dealer they gave me didnt have any thing like that on his computer and sed they must have put them as a dealer because they thought for some reason they could order it direst for me.
does any one no what this 144 mini blower cost because on the site it doesnt say. i think it would be a realy cool thing to put on my engine. and am realy intrested in it.
Old Feb 27, 2003 | 05:25 PM
ben71's Avatar
Car: 1970 Chevelle
Engine: 540" BBC
Transmission: TH400
Re: only one problem
Probably in the $1,500.00 range.
Ben
Old Feb 27, 2003 | 10:05 PM
dans82bird's Avatar
Engine: 302
ditto... check www.summitracing.com and jegs.com... they seem to be the best priced... about 1500 bucks give or take
Old Feb 28, 2003 | 01:44 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
using the part # HLY-77-144CSB-1 at summit I come up with $1699
Old Feb 28, 2003 | 03:18 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
<b>he had...</b>
HAS, dan, 142 i HAVE. the 144 B&M was the one i sold....
<b>cost</b>
The cheapest universal blower weiand sells is about $1599, but you can get 10% from summit to make that cheaper (like I did, cost me $1380 after everything)
B&M isnt the choice for blowers anymore anyways. they make expensive polished blowers...
weiand make satin aluminum blowers without the shine for the right price.
Old Feb 28, 2003 | 03:29 PM
ben71's Avatar
Car: 1970 Chevelle
Engine: 540" BBC
Transmission: TH400
Originally posted by Kingtal0n
<b>he had...</b>
<b>cost</b>
The Weiands are arguably built better too. The B&M design uses teflon strips on the rotors to seal the air in the casing. These strips tend to wear out over time causing leakage. The Weiands don't use the teflon strips. Instead they use tighter machining tolerances to prevent the leakage. I've been more than pleased with mine.
Ben
Old Mar 1, 2003 | 11:57 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
<b>he had...</b>
<b>cost</b>
have any pics?
exactly how close was the clearance between it and the hood?
how tall of a air filter can you run?
what carb are you using?
Old Mar 2, 2003 | 12:07 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
pics? my website has several.
geocities.com/kingtaling
Old Mar 2, 2003 | 12:51 AM
z28monster's Avatar
Car: 86 IROC-Z
i want one
ive mad eup my mind i am going to get one of those, how much of an increase in power did you get by adding it to your engine was it night and day or was it slightly more powerfull.
also if any one has one for sale that wants to get rid of it give me a shout i am very intrested if i dont by one used i am definatley getting one this summer around june.
Old Mar 2, 2003 | 02:13 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Well it adds more than just top end horsepower you know. The basic advantage is an instant volumetric efficiency boost, no matter what RPM your at. That means better throttle response, better drivability, and of course, a gob of extra power.
but how much of a gob? That depends on your setup. these blowers dont like big cams, or high RPMs. a small cam for a 350, like the XE262, is more than enough to erk 500+ horsepower, provided you have a decent set of heads.
just remember timing and compression ratio (detonation makers) need to be conservative to allow this boost in VE% to take place without blowing stuff up.
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
codeysabatini
Nov 10, 2015 04:07 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
09ave
Sep 7, 2015 06:03 PM
