Knock sensors and solid roller camshafts.
Old Feb 26, 2003 | 09:05 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I posted this on the DFI board as well, but I figured some of you all might have ran into this.
Friend of mine is running 9.30s on a 400sbc, solid roller cam and a D1x blower with Gen 7 DFI. He was running 12lbs of boost and running pumped gas. He wants to continue running pumped gas, but has since upgraded to a D1R (believe) and is now running 18+lbs of boost. He wasn't running the knock sensor last time cause the solid roller was giving the knock sensor false detection.
He wants to get the knock sensor back to work, but to avoid the solid roller from making it show as pinging.
He called the acell dfi guy and he said he ought to try using a buick 3.8 knock sensor and a Spark Control Module from them as well. Does that work? If so how?
Is there another way around this?
Thanks for any help.
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
masonta
Sep 1, 2015 06:40 PM
