400blocks with boost
Old Mar 14, 2003 | 04:52 PM
True Power's Avatar
I recall Guido (maybe someone else) saying stock 400 blocks can take up to around 15psi before they crack. Is this correct and/or what is the "general" limit of these? TIA
Old Mar 14, 2003 | 08:14 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
Boost alone is very rarely the cause of a cylinder block failure with the proper preparation, typically head gaskets will fail before anything else. Generally, detonation and/or excessive rpm is more detrimental.
Old Mar 14, 2003 | 08:43 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
use splade caps
Old Mar 15, 2003 | 07:37 AM
Guido's Avatar
Car: 2000 Trans Am
It is commonly accepted that the 400 block is not as strong as a 350 casting due to thinner cylinder walls. The machine shop I had my Dart block prepped at explained to me that the factory 400 blocks, even with splayed studded mains, can take up to around 650ft/lbs of torque and they start pulling the crank out the bottom.
Tory Hess of this board broke one in his Formula with a big Vortech on it. Split the cylinder wall open.
I didnt want to go through that, so I ditched it and bought a Dart block.
Old Mar 15, 2003 | 06:01 PM
True Power's Avatar
That's what i was looking for, thanks guys
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
