Getting heads for FREE?
Old Mar 17, 2003 | 07:44 AM
CustomCarShop's Avatar
One of my friends knows this guy getting rid of a set of Heads for a 350 for FREE. Supposedly, they are ported, have a bullet-proof top end and a couple other mods. Anyways, I believe theads are off of a Carburated car.
I am intsalling a 350 TPI in my car very soon & Im wondering if I should get these heads & put them on my engine, or would it not run properly becuase they were off a Carburated car?
Old Mar 17, 2003 | 07:58 AM
Guido's Avatar
Car: 2000 Trans Am
They will work fine.
Old Mar 17, 2003 | 04:48 PM
I heard somehting about the 4 centwer bolts wont bolt up to the TPI Intake manifold?
Is this true?
Old Mar 17, 2003 | 08:51 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
get them anyways. If they don't fit... Ebay it is.
Old Mar 18, 2003 | 10:30 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
they're free, supposedly worked heads. i'd MAKE them work.
Old Mar 18, 2003 | 04:13 PM
Guido's Avatar
Car: 2000 Trans Am
In 1987, GM changed the angle of protrusion for the bolt through the intake into the head on the 2 intake bolts in the middle on either side.
If you have older heads, and a newer intake, the intake will not bolt on. UNLESS, you get a grinder and elongate these holes. It has been done before so is no big hurdle. Or you could find a pre 87 intake if that becomes the case.
Good luck.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
