More TT questions
Old Mar 22, 2003 | 10:33 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
More TT questions
First I have to say that I have been lurkin around for a couple of months now and am seirously thinking about a JY tt set up for my car. Alot of you guys have done similar setups to what I am thinking about but there a few diffrences to what I want to do. First thing is that I want to do it to a 305 and it is gonna be pretty mild. I'm not looking for a speed demon just somethng that will suprise a few ppl. Mabey high 12s (350-400 ish horses) now on th the real questions.
Would 45 trim t25s be large enough for a twin setup on a 305? The turbos I am looking at are from late model DSMs. I bieleve they are .45/.48 (compressor/exhaust). These turbos are a dime a dozen and would be really cheap to obtain.
Old Mar 24, 2003 | 08:03 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The T25's are an Ok turbo. I have one in my TSi... well, the 16G is on its' way. It is a little undersized in a DSM though, the boost starts to fall off pretty bad in the higher gears.
If you did pt them in you would have no top end. With the larger displacement and poor top end charactoristics you are not looking at a good combination.
Stick with the tried and true turbocoupe turbos and turn the boost down. You are better off running on the low side of the efficiency curve on a turbo.
Old Mar 25, 2003 | 07:17 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
THe more I think about it the more I agree with you. not to mention I think I have found a pair of t3s for $100.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
