Where to find Aluminum Planks?? Paging Saturn5!!
Hey,
I can't find anyone to supply me a piece of 5052 or 6061 AL (alloy isn't critical) with these demensions 10.25x16.25x0.375
Anyone have any good suppliers??
A local guy wanted $116
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Rooster - Call your metal scrap dealers locally. AL sells for under $3/lb for large lots, and should be well under $10/lb if you get hosed. The cost depends on how accurate it must be. If it can be 3/8" thick billet, about 10" x about 16", it'll be much less expensive than if they need to machine it to .375x10.2500x16.2500. You might get lucky and find a piece of bar stock that's 12" wide x long enough. In either case, you could buy a scrap piece of 3/8" thick bar stock, take it to a local machine shop, and have them mill it to size for less than $116. Most billets you'll find will be 6061. Good luck!
Andris
Andris
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: Where to find Aluminum Planks?? Paging Saturn5!!
Originally posted by rooster433
Hey,
Hey,
www.onlinemetals.com
sorry.... missed this while I was rebuilding the puter..
ambainb
Apr 25, 2016 09:21 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
