What shot of N20??
Old Mar 26, 2003 | 09:36 AM
87transam5.7tpi's Avatar
What shot of N20??
I was just seeing what people would recomend for a safe amount of N20 on my new engine. Here are the specs. I was thinking a 200hp shot at the track 150hp on the street.
thanks
Josh
TRW Forged pisons
Polished Stock Rods
New Crank
ARP Wave-Loc Bolts
Balanced Rotating Assembly
Josh
Old Mar 30, 2003 | 10:30 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
i wouldn't mind knowing that myself... i am gonna run TRW pistons in my 355 w/ LT1 PM rods, and a cast crank... and probably the wave lock rod bolts...
Old Mar 30, 2003 | 10:41 PM
looks like me or you are just gonna have to try it man :-D
how bout you first
Old Mar 31, 2003 | 07:23 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
LoL... if i can get the motor in the car here before too long i will... i don't see why you couldn't run a 150 shot by any means... some are running that on cast pistons no prob... just gotta gap your rings right for the nitrous...
Old Apr 2, 2003 | 09:30 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
HEY 87transam5.7tpi where did you get that hood. I love it . looks bad a$$
:hail: :hail: :hail:
p.s go for the whole 200hp
Old Apr 2, 2003 | 09:40 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
hey do you have anymore pic's of your car? I would like to see some
Old Apr 3, 2003 | 01:34 AM
matts90firebird's Avatar
that hood is called a 2 inch cowl i believe
Old Apr 3, 2003 | 08:00 AM
bluedude. the hood is aharwood 2.5in cowl. you can get them from summite for like $460 or so I believe. also if you do a search of posts made by me I recently posted pictures of my car in progress. its getting new everything :-D
Josh
Old Apr 3, 2003 | 09:34 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
sorta off the topic but. ..
would a 75hp shot every once in a while be fine on a stock engine?
or should i upgrade something else?
i've got decent plugs and just put in a new fuel filter, assuming my stock fuel pump is still good with only 45K on it.
thanks.
Old Apr 3, 2003 | 10:39 PM
Chris B's Avatar
I think the answer to your question is pretty simple. If you dont get greedy, I would say you should be able to run a 75 shot for quite some time on a stock motor. I would however suggest your motor be in good running condition and not have an excessive amount of miles. My stock 163k shortblock didnt do so bad. I've run a lot of N20 through it, but like all good things came to an aburpt halt during an NA run at the track...Broke Block Admittedly my power level was a bit different and my compression ratio was higher. So take that into account as well. Anyways hope that helps some.
Old Apr 4, 2003 | 07:08 PM
Car: '89 GTA
yes that does answer my question, thanks.
my gta has only 46K miles and runs great. i won't feel the need for greed and can live with just a 55-75 boost once in a while when needed.
Old Apr 8, 2003 | 02:02 AM
onebadwagon's Avatar
hell, spray a 200 on it, if its not going to break your heart if it goes, dont worry.
if you cant afford another motor, just leave a 150 shot on it, and spray til your hearts content.
i say pill it til ya kill it.
adam
Old Apr 8, 2003 | 05:42 PM
91REdZTPI's Avatar
Ive ran 20 bottles worth of 150 shots through my stock short block at 150k it dosent burn a drop of oil and runs great make shure that your ignition is in good shape and use the right heat range plugs (not platnium) I use ngk ur4s they seem to work good and they are about a 1.20 a peice
Old Apr 8, 2003 | 06:40 PM
Car: '89 GTA
well i'd be using a dry kit from zex, so i don't think i'll be going more than 75.
the car/motor only have 45K, it would be a waste to kill it b4 it is ready to go with too much boost.
my ignition system has new msd wires, cap, coil, rotor and 6AL. plugs are basic NGK ones. so hopefully i'm set!
i'll probably do it this summer after a few more mods. (exhaust, ram air, headers).
any idea what all this might get me at the track, 14 flat? 13.9?
gta892000
Aug 11, 2019 11:16 AM
Mirror Image
Oct 29, 2017 09:51 PM
85cmroz28
Oct 4, 2015 09:44 PM
JSDaddy189
Sep 26, 2015 03:50 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
