Fuel Pres...with my blower setup
Old Mar 26, 2003 | 08:40 PM
Mubie's Avatar
I just got back from my local speed shop and I did a dyno run today. I say my most power around 4300-4500 @ around 309ftlbs for the best torque and 234.5 rwhp. The only mod I have now are MSD coil ,flowmaster cat-back and an airfoil @ the throttle body.
My ATI-P1SC arrives this Friday and I'll install that with a MSD-6AL. What should my fuel pressure be at ?? I was running REAL rich (like 10.1 AFR) after 3000 rpms on the dyno today. What do you guys run for a fuel pressure?
1 last thing, I'm planning on running the blower with the 9lb pulley it came with. Any suggestions or experiences?
Thanks,
AC
Old Mar 28, 2003 | 10:33 PM
Damon's Avatar
The blower kit should come with an FMU. It's job is to increase fuel pressur in relation to boost. Usually at a ratio of about 4-6 PSI/pound of positive boost. As such, your base fuel pressure should not have to be changed very much if at all (assuming it's right to begin with). You will have to make sure that your fuel pump is up to the added flow and pressure that will be demanded of it.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
