HELP!!! with Nitrous MasterMind
Old Apr 5, 2003 | 01:20 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
Have just hooked up my Nitrous MasterMind, and now my car won't start. I am running the GM Heavy Duty ignition and distributor which is just a MSD 6A and magnetic pick-up distributor. Anyone else have a similar style set up? I have no spark or tack indication when the MasterMind is hooked up. I am hooked up as per figure 22 of the MasterMind instuctions, which is MSD ignition, NMM, hook up with magnetic pick up distributor.
Thanks, Mike
Old Apr 6, 2003 | 09:15 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
no one has any thoughts?
Old Apr 11, 2003 | 11:11 PM
83 Crossfire TA's Avatar
The JNMM is fairly fool proof. As long as you connect all the wiring correctly they tend to work and I’ve never heard of one failing. The hassle is getting all the wiring connected without loosing track somewhere or building a rat’s nest.
It’s only got one connection where it intercepts the ignition trigger signal, if you can’t find any wiring mistakes I’d start with disconnecting there and reconnecting the wire that you cut and see if it runs. If reconnecting that one wire makes it run then I’d give the rest of the JNMM a harder look, if not then something else is messed up that’s keeping you from running.
Old Apr 14, 2003 | 07:09 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
i'm using a mag. pick up dist. so the 2 wires from the dist. go to the orange and purple wires to the NMM andf the yellow goes to the white in to the ign. box . jacobs said to send it back to exchange it so its on its way now
mike
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
