compression to high for a blower???
Old Apr 16, 2003 | 04:44 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
what would be a safe compression ratio for a blower on a street driven car? my GTA has 10.5:1 is this too high or i be better off just spraying it?
Old Apr 16, 2003 | 07:46 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Thats way to high, unless you want o run 100+ racing gas.
Old Apr 16, 2003 | 10:44 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
to have a serious amount of boost that compression is way too high. now if we are talking like a 5-6 PSI of INTERCOOLED boost setup that can be done easilly. But thats still a pretty expensive investment for only 5-6 PSI;
your probably better off using spray until you can lower your compression to about 9.5:1 or lower, then you can run alot more boost (intercooled) and make a ton more power.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Jan 10, 2020 08:55 PM
buckeyecelt
Sep 24, 2015 05:50 AM
327IROC85
Sep 23, 2015 12:11 AM
WhteRbt
Sep 21, 2015 09:48 AM
