79 turbo TA manifold, with thunderbird turbocoupe turbo
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
would this be possible? i could get those real cheap at a junk yard, i know the old turbo TA's turbine is small, but the turbocoupe has the mustang svo one (garret T3). so the manifold would bolt right onto any SBC and the T3 should bolt well to that...with an oil line made with a T fitting from the oil pressue senser and a return line into the oilpan, this would work right? oh ya and a blowthrough carburator
The manifolds won’t work, like someone already said, it was a Pontiac block.
All T3’s aren’t created equal, the largest turbocoupe T3 (early 5 speed cars) was a 60trim/.63, where the 301 turbo used a GM specific 60trim/.82 that had a GM style flange, rather then the normal Garret one that almost all other T3’s use.
Hotrodboba400
Dec 10, 2019 07:07 PM
sailtexas186548
Feb 17, 2017 03:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
