Eaton M112 Runs!
Eaton M112 Runs!
I can't believe it !
Thank ***!
I cranked it up a few times today.. I suspect the tuning to be way off because it surges at an idle.
There is one big problem
It is increadibly loud! I can barely hear over the thing.. its very painfully loud I'm unsure if its because i don't have a air cleaner on it or what but you can distinctly hear it from inside the house. Its even scareing the crap out of the pets. I"m going to call the people who rebuilt it and see what they have to say about it tomarrow.
http://community.webshots.com/album/73249682zNpxhw
Hey SATURN5... If you would mind i would like to talk to you and see what you think about the loudness of this thing... prehaps you can give me a call or I call you.
Thank ***!
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: Eaton M112 Runs!
Originally posted by rooster433
Hey SATURN5... If you would mind i would like to talk to you and see what you think about the loudness of this thing... prehaps you can give me a call or I call you. [/B]
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
dont those have lobes that can be damaged by debris? I would get an aircleaner on there asap. my blower ingested a small piece of lint and i thought it was going to fall apart! lol.
Not sure if it has one but did you fill the synchro gear lube reservoir (with the right stuff, to the correct level)? I bet they make a LOT of noise just before the synchro gears shred themselves.
If the lobes were hitting eachother or the case you'd know it instantly- it would lock up tight as a drum.
Alvin,
Did you call the Canadians? What did they say? Did you get the boost gauge figured out? I really hope the changes to the upper will make it fit under the stock hood. I think she looks best that way and it will make for one hell of a sleeper.
I have heard the sound over the phone and it is more than lobe "break-in". The best I can describe is a girl screaming at the to of her lounges. I listened to it for about 30sec and had to take the phone away from my ear. It was really starting to hurt.
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I know very little about Eaton SC. What is the M112 off of, and is it big enought to adequatly power a 350? Just curious.
I called the guys and they said a good bit of noise is normal but i took the upper intake off and found a ton of heavy SC oil over the back of the blades and the blower makes a nice grind when you turn it over by hand now..
i'm mailing it back tomarrow and fixing it up for me
Car: 1992 B4C 1LE
I know the 112 on a lightning while dynoing we took off the airbox and it was so loud I might have gotten ear damage.
jeez... i know how you feel.
I took the upper intake off and found a ton of nasty supercharger oil everywhere and excessive bearing noise that wasn't there before i installed the blower.
The bearing i'm referring to is the one on the back of the blower furthest away from the pulleys
Car: 1992 B4C 1LE
why not draw through? the guy I talked to at the magnussen place said they arent made to wet flow but tell that to all the lightning guys running a single fogger.
Car: 1992 B4C 1LE
yeah but it turns out to be BS in a practical sense. for you I would run a sigle fogger nozzle after the blowers or mebe a 5151? ;-) hmmm
That sucks killing the blower like that. I know from frustration on stuff like that.
I got back my 142 after locking it up a few months back (also mysterious circumstances) and bolted it back on. Started it up. Fired immediately and then I saw HUGE clouds of oil smoke out the exhaust a few seconds later. Shut down and popped the carb and blower back off to have a good look. Couldn't find anything wrong so I thought something happened to the motor internally. I decided (after a few beers) that the only honorable thing to do was to run it till it blew up. Put it all back together. Started it and revved it up near redline a few times. Oil clouds slowly went away.
Turns out there was a LOT of assembly lube and stuff all over inside the blower from the rebuild process. Hundreds of miles later- runs fine, no oil on the plugs at all, nothing out the pipes. I was a lot more lucky than you were.
The coating on the rotors is not absolutely necessary for its operation. The older M series blowers do not have it (the rotors on my brothers M90 are uncoated). The coating was added later to take up some of the tolerances and build a fraction more boost at the same rpm. I really doubt that fuel would hurt it, but if it did it would be easy enough to strip off the rotors. Based on what Ive seen, the coated rotors work better at low rpms where the uncoated ones work better at high rpms.
My bigger worry would be the case bearings, I dont believe (from disassembling them) that they have correct seals on them to prevent gas from getting in and dissolving any lubrication.
There might exist correct bearings since Magnusson does have carbed prototypes running (Ive been thinking of doing something similar with a TBI truck and one of these).
FWIW, the lube that eaton uses in its gear case is some seriously nasty and expensive stuff. Ive tried vacuuming it out using a mighty vac and it ruined the tubing and container. If youre looking for the lube for cheaper (ford sells it for like $20 per bottle, and you need 2 or more), GMs price is half of fords.
I don't get why the majority of the oil and tephlon was at the air input side of the blower when the oil is kept at the other end.
As SATURN5 can testify something was definately wrong with my unit.. it was so loud the niebhors heard it it was really really loud
yeah i know... after talkign to SATURN5 i guess its ineveitable.
I really want this thing somewhat quiet. Hopefully with a long intake down and maybe a paper filter inside a airbox it might quiet it down a bit
My M112 has sound baffles in the output, i know the M90 doesn't also my throttle body is ahead of the blower.. maybe without overdriving the blower too i can be a little more quiet
i can only hope that its quiet under part throttle and idle.
Is your bothers at least somewhat quiet at an idle?
Remember also that the case that hes using has been heavily ported, the inlet has almost 2x the cross sectional area and every sound deadening ridge/slot in that case has been cutout in an effort to maximize flow. That one is one of the ones that you see Mike Sitar porting on his site and we cut a lot more out of it then he did.
Is it quiet at idle? Well, quieter then at WOT
like I already mentioned, minimal exhaust and turndowns behind a healthy engine and you cant hear the exhaust (with the turn downs we did get the change that the pavement and floorpan throbs with the idle, but you cant hear whats causing that throbbing. Of course, I bitch about it much more then he does, but I think that he should try to make it sound as much a sleeper as it looks.
like I already mentioned, minimal exhaust and turndowns behind a healthy engine and you cant hear the exhaust (with the turn downs we did get the change that the pavement and floorpan throbs with the idle, but you cant hear whats causing that throbbing. Of course, I bitch about it much more then he does, but I think that he should try to make it sound as much a sleeper as it looks. Loud at WOT I can beleive- I can hear my 142 screaming it's lungs out EASILY over the 2 chamber flowmasters. Idle, though, it's quiet as a church mouse. And there's little "sound deadening" other than the closed throttle plates.
What makes this particular Easton unit so loud?
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
novaderrik
Aug 10, 2015 12:44 PM
