7lbs with this cam
Old May 17, 2003 | 04:13 PM
TA88GTA's Avatar
7lbs with this cam
Hey guys im picking up an A trim next week and i just wanted to know what you guys think about how my car will react to it with my cam/motor combo. Heres what i have... 355, edelbrock performers, stealthram w/ lingenfelter twin 58mm TB, 24lb injecters and a CC XR282HR w/ 1.6RR. The specs are 230/236@.050 and .545/555 lift. Im also gonna be running a small shot of nitrous when needed. I was thinking along the lines of a 50shot.
So tell me what you think
Old May 19, 2003 | 02:28 PM
TA88GTA's Avatar
Anyone?? I just want your thoughts on how well this cam will work with the blower.
Old May 19, 2003 | 09:22 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
whats the lobe sep?
Old May 20, 2003 | 02:21 AM
TA88GTA's Avatar
The lope sep is 110
Old May 20, 2003 | 03:34 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I understand that lobe separation doesnt necessarily give the overlap but it is a good indicator especially on "comp cams" cams. comp does grind a little overlap in and this will help with the boost and nitrous. You may find you can actually run more of both with that cam if you want. My JYD (see sig below), used to run 150 shot with a cam that had a massive overlap and 106 lobe sep.
Old May 20, 2003 | 05:56 PM
TA88GTA's Avatar
So what your saying is that it will be safe to run a little more boost or nitrous with this cam??
I was just afraid that the overall size of this cam was going to be too big to make good power with boost.
Old May 20, 2003 | 09:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you'll be fine
Old May 20, 2003 | 09:40 PM
TA88GTA's Avatar
Cool thanks. If anyone else has info or ideas feel free to add them, and thanks again B4Ctom1.
Old May 20, 2003 | 09:49 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
oh trust me they will...
Old May 21, 2003 | 03:57 AM
83 Crossfire TA's Avatar
I think that the cam probably has a little more overlap then youd really want, but I think that youll have a bigger problem with the blower, it wont move that much air, and Ill bet that you wont see more then a few PSI boost and not much added HP. Typically, a-trims should top out at about 400hp at the wheels, and the combination that youve got should be capable of that now assuming its tuned right.
Old May 23, 2003 | 12:08 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I wouldn't go lower than a 112 LSA. Especially in a COmp cam that has a built in 4 degree advance on the ICA. My cam would be a little better for your setup (cc XR276HR-12)
.503/.510
224/230 @.050
112 LSA
108 ICA
Then just use 1.6 rockers.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
