how well do XE cams work with nitrous?
Old May 20, 2003 | 11:41 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
well, my shortblock is on it's way out, so i'm in the process of building another 350 with stock crank and rods, arp rod bolts, and trw forged pistons. Gonna be reusing my trick flow heads and rpm intake with 750 demon. Right now i have a Comp Xe274 cam, and i love it. I'd like to reuse it with the new motor, which will be seeing something around a 150 shot. I've heard however that the XE cams don't really work well with nitrous.
If not, whats a good cam to go with? I'd be looking for something similiar to the xe274 that won't be a pig off the juice.
sorry if this has been discussed, i searched and didn't find much.
Eric
Old May 21, 2003 | 12:03 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i'm going to fined out 355 xe268 150 shot
Old May 21, 2003 | 11:32 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if ur goin to use nitrous Jegs sell the Compcams Nitrous HP cam kits.
for the 274 cam its 274/292* adv. duration, 488/.501'' lift and has an rpm range from 2400-6500rpms.
the regular XE cam fopr the 274 is 274/286* adv. duration, 487/.490'' lift and has an rpm range of 1800-6000 rpms.
im thinkin of gettin either the 262 or 268 nitrous cam for my 305 becuz i plan on puttin nitrous on my motor. and figure if this cam is made to take the hit of nitrous it will be good.
Old May 22, 2003 | 12:46 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i'm thinking i'm just gonna resuse my xe cam for now, and keep the shot around 100-150...
unless anyone violently disagrees....
Old May 23, 2003 | 11:16 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I use the xe 268 and a 125 hp shot. Works really well. Whoever told you that xe cams don't work well with N20 doesn't know what they are talking about.
Old May 23, 2003 | 01:32 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I have sprayed a 150 shot more than a few times (ok..many many times) with my XE274 and have not a problem to date with it not working...Spray it!
Old May 23, 2003 | 02:54 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
[Montgomery Burns voice]
Exxxcelllennnt....
[/Montgomery Burns voice]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
