Hello, my name is Todd and I'm addicted to Nitrous
Old May 28, 2003 | 10:50 PM
toddlsf's Avatar
Ran my best tonight, first night out with the nitrous. 11.57 at 127 mph. Love the stuff, except that I went through one bottle in about 5 runs.
Attached Thumbnails Hello, my name is Todd and I'm addicted to Nitrous-img_0631small.jpg
Old May 28, 2003 | 11:15 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
nice run, now go get yourself some traction. You've got enough mph there to run high 10's. How big of a shot are you spraying?
Eric
Old May 28, 2003 | 11:23 PM
toddlsf's Avatar
200 shot. I was on Nitto drag radials, but never hooked up. My 60 foots were between 1.9 and 2.0. I also ran an 11.61@123, 11.78@125, 11.72@126, and a 11.80@127. I also had a few 12 second runs when I ran out of nitrous, and when I forgot to arm the system. I won't list those.
Todd
Old May 28, 2003 | 11:48 PM
Justin 87 GTA.'s Avatar
nice!
Old May 29, 2003 | 12:06 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
you mind listing your engine specs? I'm looking for about the same results you seem to be getting with my new motor build. I want to be well into the 12's NA, and at least mid 11's on the spray.
Eric
Old May 29, 2003 | 11:40 AM
toddlsf's Avatar
Stock 94 Corvette LT1 block,
LPE CNC ported heads
58mm throttle body
CC 306 cam
Crane Chrome Moly Rockers
Trickflow pushrods
Cloyes Double roller timing chain
Meziere electic water pump
SLP 1 3/4 shorty headers
SLP two on the left exhaust
No Cats
10 inch lock up Art Carr converter
built 4l60e trans
8.8 mustang rear w/ 3.73 gears
Powertrax lock right locker
I'm forgetting some things, but that's about it. The 11.57 was run through the muffler. I have a cutout, but didn't uncap it for that run. I basically pulled in off the street, opened the bottle and ran it. Not too bad. I'm still smiling.
Todd
Old May 29, 2003 | 03:47 PM
Guido's Avatar
Car: 2000 Trans Am
Congratulations!! I guess this was at Muncie right?
Thats awesome! Get a good tire and watch it fly.
Old May 29, 2003 | 05:26 PM
toddlsf's Avatar
Yep, it was at Muncie. It sprinkled a little off and on all night. There was hardly anyone there. I definitely need some slicks on it. A buddy of mine has some, and I'll definitely get a chance to use them. He's already promised. I got about 10 runs in and that was between 6:30 and about 9:00. I bet there were only about 20 or 30 cars there.
Todd
Old May 29, 2003 | 06:16 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
You mentioned an 8.8. What year mustang is that from? That sounds cheaper than a 9".
Old May 29, 2003 | 07:04 PM
BADDEST305's Avatar
Car: 1991 z-28
Engine: 434--654hp---601 torque
Transmission: ATI POWERGLIDE
Axle/Gears: mose 9" / 411 gears
hello todd, my name is bill and i to am an addict
great times!!
Old May 29, 2003 | 07:09 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
hi
my name is ed and im addicted to nitrous also havent ran it yet but i already like my kit and it should put me into the low 13's if i can get it to hook
Old May 29, 2003 | 07:12 PM
JR305's Avatar
toddlsf does that corvette LT1 have hypereutectic pistons? I know the camaros do. If so it looks like they can take a bit more nitrous than most people say. I asking because I have a ZZ4 block that I will probably end up spraying in the future.
Old May 29, 2003 | 08:41 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
damn.. u have ther same problem i have.. except i was on ET streets goo dluck hittign the 10's
Old May 29, 2003 | 09:16 PM
toddlsf's Avatar
I really don't know what the pistons are. I think they are the same as the Camaro's. I think the only difference between the Camaro LT1 and the Corvette LT1 is that the vette is 4 bolt mains. It seems to handle the RPM's too. The trans was shifting about 7,000 RPM. I think I'll lower the shift points a little. The PCM is telling it to shift about 6400, but it doesn't quite hit it then with the nitrous.
Todd
Old May 29, 2003 | 10:03 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I would also like some info on the 8.8. I have been thinking of doing one with 9bolt axle tubes and axles for a while.
You seem to know all the cool cheap ways to go fast.
Any info would be appreciated. Congrats on the killer times.
Kory
Old May 29, 2003 | 10:16 PM
toddlsf's Avatar
I have the Southside kit on my car, so the torque arm is gone. That made it a lot easier. The housing is just a mustang housing, that I welded my Camaro brackets onto. I put a powertrax lock rite locker in it and bought moser 31 spline alloy axles. I had them make the axles 1.25 inches longer than the mustangs. Then, I just adapted the brackets from a 96 Firebird to put the disc brakes on the back of it. So, it's really pretty easy. I'm kidding, it took me a while to do all of it. But, I've owned the car for about 13 years now, so I've had a little time to think and work on the car. It has really come together in the last couple of years, since I put the LT1 in it.
Todd
Old May 31, 2003 | 08:35 AM
Guest
Guest
Posts: n/a
great times!!
how did you get 11's out of a 305? i'm looking to put NOS on my car and i hve a built 305 i wanted to know what you did to be able to run 11's
Old May 31, 2003 | 04:35 PM
Car: 88 Iroc
Transmission: t 56
If I read his sig correctly he has a heads and cam lt1. Where did you get 305? I'd be really impressed if it were a 305.
Kory
Old May 31, 2003 | 04:43 PM
True Power's Avatar
Kory
He's talking about Baddest305
Old May 31, 2003 | 05:16 PM
Guest
Guest
Posts: n/a
Kory-88Iroc 350 tpi please reread my quote and then please reread the post and you will see that he has a 305 that is running 11's
Old May 31, 2003 | 05:53 PM
BADDEST305's Avatar
Car: 1991 z-28
my86firebird, click on link i have all my mods listed. and yes it is a 305!!http://www.fbody.com/timeslips/member.cgi?id=235
Old May 31, 2003 | 06:24 PM
Car: 88 Iroc
Transmission: t 56
My bad I thought you were talking about Todd.
Kory
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Sitting Bull
Aftermarket Product Review
40
Dec 2, 2001 12:17 AM
ws6formula89
Oct 7, 2001 02:45 PM
