EEEEKKKK having rough time
Old Jun 8, 2003 | 08:55 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
well i got the TBI Nitrous Kit installed and am having a pain in the *** time trying to get it tuned right
i took it down the street with no tags and hit the switch but soon as i hit second gear it bogs down and blows black smoke it looks like a diesel then it floods until i release the switch so something isnt agreeing with something but eventually ill get it straight
just thought id keep you all informed on the progress so far
Old Jun 8, 2003 | 09:02 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
oh BTW
1st gear is pretty nasty
:rockon: :rockon: :rockon: :rockon:
Old Jun 8, 2003 | 10:26 PM
MdFormula350's Avatar
u will get it, keep keeping us posted.
Old Jun 9, 2003 | 03:42 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Is it a wet or dry kit? If its a wet kit you may want to think about dropping the size of the fuel pill? Actually now that I think about it what were you trying to spray with right off the bat? If you had small giggle juice pill in it and a big fuel pill then that is probably why you were flooding your motor. You definatley dont want to make that a habit...you'll end up washing out your poor ol' rings/cylinder walls!
Old Jun 10, 2003 | 03:09 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
make sure bottle PSI is up. You are running a relay not just the moicroswitch right? the microswitch only install can do that when the heat builds up in the switch the connection goes high resistance and the selenoids or one of them closes. You are lucky that the thing is going super rich and not super lean.
Old Jun 11, 2003 | 05:19 AM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
These are very good points as well.
Frozer!!!
Jan 19, 2024 04:55 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
