got my first 10sec pass!!!!yessss
Subscribe
Jun 24, 2003 | 01:31 PM
Well I finaly got my first 10 sec pass on sunday with a 200 shot. It went a 10.96 @122.92. needless to say I was happy as can be! just thought I would come here and share
all with a little 355 and 9.45 compression
Drew
Reply 0
Jun 24, 2003 | 02:20 PM
NICE! I cant seem to recall, what are all your specs again?
Reply 0
Jun 24, 2003 | 02:33 PM
damn, you were HOOKING it looks like.
congrats man.
adam
Reply 0
Jun 24, 2003 | 02:56 PM
Quote:
congrats man.
adam
I had a 1.52 60ft. it went a 6.99 in the 1/8th @99 it was also 93 deg that day to here in ga.
Reply 0
Jun 24, 2003 | 03:00 PM
Quote:
· 355cid 9.45:1 comp
· Fully balanced rotating assembly
· Stock rods with ARP bolts
· Stock crank with polished journals
· Probe Industries Forged Pistons
· Dura-Moly Rings
· Rollmaster True Roller Timing Set
· Melling High Volume Oil pump with arp stud
· Stock oil pan
· Pro Race balancer
· Stock flex plate
· Stock Timing Cover
Valvetrain:
· Comp Cams Roller Lifters
· Comp Cams Pushrods
· Comp Cams Xtreme Energy Cam 224-230dur@ 50 .530-.540 lift with 1.6rr
· Summit 1.6 Roller Rockers
· AFR Springs up to .550 lift
Heads:
· AFR 190cc Heads, clean up work after cnc porting, flow 268int and 200 exh
· Manley int valves
· REV exh valves
· AFR locks and retainers
· AFR guide plates and rocker studs
Exhaust:
. hooker long tubes
. flowmaster 3in single outlet
. custom y-pipe
Drivetrain:
. TH 350 with
. Midwest Converters billet NOS Cnverter 9.5in 3800 stal
. 1LE drive shaft
. moser 9in, 35 spline axles, nodular center section 3.70's
Suspension:
. Spohn Control arms
. Spohn Torque arm
. Spohn Pan Hard
. Kyb Struts and shocks stock springs
Car weighs 3440 with me in it, and I weigh 235. Motor is Currently for sale for 3500.00 less intake and carb.
Drew
Reply 0
Jun 24, 2003 | 05:04 PM
You crank a 10 and then immediately put the motor for sale???
Let me guess: 9s. Right? It's a sickness. It really is.
Reply 0
Jun 24, 2003 | 05:09 PM
Congratulations! Feels good to see 10.xx right? hehe
Reply 0
Jun 24, 2003 | 05:46 PM
I'm warning you Drew..leave it alone and in the car.Don't be an ***.hehehe..how much faster you really gonna go with the other combo?:lala:
Reply 0
Jun 24, 2003 | 07:03 PM
Ya I know. I have been trying to sell it for like 3 months now. I have just been playing around with it getting it run the best it can. I never expected it to run a a 10 sec pass! I was astonished when it did. Who knows I might end up keeping it in the car if nobody buys it soon I will just sit my 406 on the stand and leave it be.........
Drew
Reply 0
Jun 24, 2003 | 07:05 PM
Quote:
Trying to catch sean!!!!! hehehe that will take a lot
Reply 0
Jun 24, 2003 | 07:06 PM
Quote:
YES it DOES !! I got out and kissed the hood while I rubed the fender while all my friends stood there looking at me
Reply 0
Jun 24, 2003 | 09:32 PM
first off congrats on the 10's:hail: second thanks for the inspiration to get to the 10"s with a 200 shot. i've been running a 150 shot and just bought a cheater kit so i can run a 180, 200 or 250 shot. i need to knock off 4/10's and hopefull on the right nite with a 200 shot i might see those numbers myself. again congrats!
Reply 0
Jun 25, 2003 | 08:07 AM
Well first off..good luck with catching Sean..you know damn well he will just go bigger..the psycho path he is..and as far as this quote "YES it DOES !! I got out and kissed the hood while I rubed the fender while all my friends stood there looking at me"..from knowing you as long as I have..it was probably more a humping of the fender than a rub..lol. Remember..I was there when you ran you first 12 second pass..@97..you was a humping that day..lol.Congrats again..scumbag!
Reply 0
Jun 25, 2003 | 12:57 PM
hahahaha. I just wish you were here for the first 10sec pass. who knows I might be up there when you get your z in the 10s this year!!!!!! and dont say it wont do it. look at my car and look at yours. its lighter, has more motor and is built stronger!
baddest305. thanx for the compliment. I ran a 11.40 I think? with a 150 or an 11.30 so it can be done with the right setup. \i think you should get there with good air and cool weather.
If I can figuire out how to download the video from the digital camera I will see if someone can host the video for a short time. I ahve one 10 sec pass and an 11.30 pass
Drew
Reply 0
Jun 27, 2003 | 07:44 PM
Hey NosFed i see all your specs except your induction, are you running TPI or carb or what? Im about to hit my TPI 355 with a 300 progressive shot in a few weeks here, just got the fogger setup installed to the manifold...
Reply 0
Jun 28, 2003 | 12:11 PM
edelbrock performer, 750dp, proform main body
Drew
Reply 0
Jun 29, 2003 | 05:21 PM
What times do you run on motor?
Nice pass man. You get any daylight under the tires?
Reply 0
Jun 30, 2003 | 11:07 AM
It runs 12.30's-12.40.s on motor. As for the daylight under the tires its wierd. It leaves harder with the 150 than the 200 ??? When I left on a 150 2 weeks ago it had both tires about 6in off the ground but since then I have been leaving on 200 and it just squats and leaves every now and then the left tire gets like 1in or so. But hey hanging the tires or a 10 sec pass ya ill take tens anyday
Reply 0
Jun 30, 2003 | 09:54 PM
hey Nosfed im also curious:
<b>Stock crank with polished journals </b>
is that the stock L98 crank? is it forged? now im curious.
Reply 0
Jun 30, 2003 | 10:04 PM
yup!!! stock crank and rods. with arp bolts in the rods and fully balanced
Drew
Reply 0
Jun 30, 2003 | 10:23 PM
eatonton GA, huh? well, i am down here in Warner Robins waiting on my motor to get done, congratulations on the great times. i am hoping for numbers like that soon. did you go to Renyolds or Commerce? how do you like Headhunters there in eatonton? i was just there two/three weeks ago with my dad and his car. it's definetly an "interesting" track...
Reply 0
Jun 30, 2003 | 10:31 PM
holy **** someone else from the area!! lol. Yeah I go to headhunters almost everyweek. I have an red 88 trans am with a 4in cowl. I went to reynolds on the 22nd when I made that pass. I just wish I could run the same 1/8mile time at silver dollar as I do at headhunters. I run 6.99 at silver dollar and 6.92-6.93's at headhunters.
Yeah heaadhunters is an interesting track, but it is also one of the coolest place to race at. Its like a big happy legal street race. I know the owners and they are cool as hell. We will have to get together sometime and go racing. give me an e-mali some time
badl98gta@hotmail.com
Drew
Reply 0
Jul 5, 2003 | 12:06 AM
Quote:
Cool, I was there at SDR and I remember seeing your car there...it was the only red GTA there. Congrats on the 10s, one of these days I'll be there, with the help of a little blue bottle of course.
I had the black IROC with the Draglites (not to be confused with the other black IROC with the headlite covers) but I was only running 12.80s-12.90s that day.
Reply 0
Jul 7, 2003 | 04:12 PM
I remember that car. I pointed it out to my friend with the other black iroc that other car runs like 13.0's--13.10's I had to always look at the wheels to see who it was. He runs the convo pro's. He is a good friend of mine we race together all the time. WHy were you off your times that day ? I thought I saw you ran some 12.30s usually.. I remeber talking to someone about your car a while back.
As for being the only red GTA there that is getting to be a norm latley. It seems as if all the thirdgens I see at events are all Z-28's or IROC's. I hardley see any trans am's or gta's at all anymore Mine is hard to miss with the 4in cowl though
Well if heaing to sdr one day lt me know maybe we can meet up or something and shoot the **** and go racing.
Drew
Reply 0
Subscribe
