Wierd water injection idea
Old Jul 7, 2003 | 10:53 PM
rooster433's Avatar
Here are some pictures..
http://community.webshots.com/album/77885215Iqhcdp
its a corvette fuel pump, water rail built out of pieces of steel and a left over LT1 fuel pressure regulator.
I made the regulator adjustable with a simple cap and screw. Right now its adjusted at 43psi.
the water injector is a left over fuel injector.. the one i would like to use is spraying a stream instead of a fog.. I put a known good injector on the system and it did fog.
I'm not sure how this is going to last in water. I'm definately not going to press my luck with alcohol.
Fast355
Dec 2, 2016 06:33 PM
toronto formula
Nov 10, 2015 06:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
86Base
Aug 13, 2015 05:06 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
