Max dry shot on a 350 TPI
Old Jun 27, 2003 | 10:06 AM
89GTA350's Avatar
Max safe dry shot on a 350 TPI??
I've put a hand on a zex dry nitrous kit for cheap. This kit is initially for 5.0 mustang. It looks like it works like the NOS kit #5115. Is it safe to run a 75 dry shot on my stock 89 TPI???
The only mods I have are custom air intake, hedman headers 1 5/8, 3in catback with dynomax ultra flow. Stock fuel pump and #22 injectors.
Old Jun 27, 2003 | 12:22 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
For running a dry kit, you look at injector duty cycles...
Injector flow rate (lb/hr) / brake specific fuel consumption (lb/hr/HP) * number of cylinders = HP at 100% injector duty
The brake specific fuel consumption (BSFC) is about 0.5 for normally aspirated engines, 0.55 for supercharged, and 0.6 for turbocharged. I use .5 for nitrous engines...
22 / .5 * 8 = 352hp @ 100% duty cycle
Most stock injectors prefer a 80% duty cycle to remain happy. So, 281.6 HP is what your injectors could supply..
Subtract the HP you're making now from the 281.6, and that's the dry shot you can run 100% safely.
I've seen injectors get stretched as far as a 98% duty cycle, but do it at your own risk
(ALL HP FIGURES ARE CRANK HP, NOT RWHP)
Old Jun 27, 2003 | 10:52 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
my experience,
a 75 shot seems to be ok but the 100-125 makes them detonate and break stuff after a while unless injectors are swapped and fuel pumps are installed too.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
