Cheap ways to lower compression on 305
Old Aug 12, 2003 | 11:21 PM
turbotim23's Avatar
Well guys I won a supercharger on Ebay now looking for ways to lowwer compression so I can run more boost. I tring to do this and not sink a lot into it! Whats the thickest head gasket for a 305? My heads have just been redone so I really don't want to swap heads. What do you think of grinding the head chambers slightly bigger or using a ridge reamer to slghtly enlarge cylinders at top? I don't want to mill pistons because they say boost will break ring lands.Any parts that could bring compression down cheaply? Thanks Tim
Old Aug 13, 2003 | 03:18 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
why what compression do you have now?
Old Aug 14, 2003 | 05:36 PM
turbotim23's Avatar
Well I supect it is just under 9:1:1 compression. The heads are small chambered and were surfaced some with valve job. If I could get it closer to 8:5:1 or better yet 8:1:1 I'd be happy. I was thinking of unshrouding the valves to the sides of the head chamber.This would lower compression and help valves too. Anyone know how far you can open head chambers up? Thanks
Old Aug 14, 2003 | 07:49 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
just get a set of dish top forged pistons, that way u lower ur compression but also have some good strong parts in there for the boost
Old Aug 15, 2003 | 01:39 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Are you sure you want to lower your compression? 305s are suprisingly resistant to detonation under boost... look at willie's setup 15ish psi on 9-9.5 compression...
Old Aug 19, 2003 | 02:49 AM
83 Crossfire TA's Avatar
Running thicker head gaskets is the wrong way to go, it will hurt quench and will make the engine more detonation sensitive. Probably the easiest way to do this well is to slap a set of 350 heads with 64cc or larger chambers on it, just make sure they use stock 1.94/1.50” valves so you don’t have clearance problems. While you’re at it, I’d probably use thinner gaskets to get the quench distance into the .040” range (if it’s a stock type build you’ve probably got about .060” or more).
Assuming that you have 58cc heads on it now, going to 64’s will lower compression about .6, if you get rid of about as much quench distance as I mentioned you’ll only lower things about .2-.3. 76cc chambers will lower things about another point.
customblackbird
Aug 15, 2021 10:16 PM
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
Leggman1
Aug 6, 2015 04:15 AM
