ATTN: WILLIE, i need HELP!
Old Aug 23, 2003 | 03:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hey man,
i am lookint to build a similar motor to yours, i will eventually run a pro-charger (blow-thru carb setup) on this too. i am trying to copy your bottom end. i see that you are using the TRW pistons. are you running a floating pin? i am currently looking at the TRW p/n L2486F pistons. are these the same as yours? they claim 9.23:1 compression, which is what your is, right? i hope you don't think i am stalking you. i am just trying to get this motor together as quickly as possible. i am running the Eagle H-beam rods with bronze bushings. i got them from cnc-motorsports for $285.95 shipped. the pistons are $359 from flatlanderracing.com. where did you purchase yours? were they cheaper?
i apologize for all the questions, but, help a brother out! thanks again.
Old Aug 24, 2003 | 04:50 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: ATTN: WILLIE, i need HELP!
Have a look at the post about a 4 bolt main 305. In there you will see that Willie is in the process of changing over everything in the engine. The TRW pistons and long gone.
Old Aug 26, 2003 | 08:31 AM
mw66nova's Avatar
Engine: 7.0L
yeah, i found it. but for a set of floating pin, forged, 9:1 pistons for a 305, Ross wants $755 and JE wants $880. can't justify that for a street motor. Willie paid over $500 for those APBA pistons and they are pressed fit. those TRW's are no longer available, anywhere. i am going to buy a set of cast replacement .030 pistons and the Eagle SIR rods. no use in spending a ridicuslous amount of money on a 305.
Old Aug 26, 2003 | 06:26 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Willie paid over $500 for those APBA pistons and they are pressed fit...
The JE pistons I bought can be installed either way, pressed or full floating. You might want to give JE a jingle. The P/N is 174002.
Willie
Old Aug 27, 2003 | 12:13 AM
mw66nova's Avatar
Engine: 7.0L
i already called them, did your pistons come with the wrist pins and spiral locks to install them in a floating application? and did they come with the spiral lock groves already in them? cause JE said that they are pressed fit only. either way, I still can't justify that much money in a street motor. thanks soooo much for the info. and good luck with the new setup...did you ever get her fired?
ronchic
Mid-Atlantic Region
Sep 10, 2015 02:32 AM
willyjoejr
Sep 3, 2015 09:26 AM
zedder 1 9 9 0
May 30, 2001 08:06 AM
Jason E
Sep 17, 2000 08:41 PM
