super chargers and cams????
Old Sep 28, 2003 | 09:57 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i'm gonna make a supecharged 305. maybe even a 335. but my problem is i really don't understandwhat to look for in a cam. Whats the differnce between a blower cam and a regular cam of simular specs?
any kind of info or suggestions on cams would are geatly welcomed. thank you in advance.
WyClef
Old Sep 29, 2003 | 02:07 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
camshafts with tight lobe seperation angles (LSA)
have increased overlap.
Overlap is a period when both intake and exhaust valves are open.
So if u have a tight LSA, your boost will go outright out the exhaust.
Id say between 112-117 LSA is what U need.
thats my opinion, maybe not 100% accurate, but close i find.
U can gat a 'blower cam' with just means no guess work for U
since the cam has the configuration needed for use with superchargers.
Old Sep 29, 2003 | 06:27 AM
Engine: peanut LB9
ok i just wanted to know if there was a differnce between the shapes of the lobes or not. and i don't wan to run a +.500 lift in a 335
Old Sep 29, 2003 | 02:50 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
That all depends on the motor...But usually around 114 LSA...also running MORE lift on the exhaust than the intake...
Like on my 355 I ran like .500 .510 114 LSA Dont remember the duration off of the top of my head...
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
