Supercharge the zz430
Old Oct 6, 2003 | 08:28 PM
AustinT's Avatar
I have a zz430 it does well with 430 hp but I would like to increase it 170 hp for a 600 hp smallblock
I am using a holley 750 vs carb and I get 22 mpg so I am not worried about loosing a couple of mpg.
I thought about buying the vortech kit but I dont know if I can reach my goal with it. My compression ratio is 9.6 is this too much? Im pretty sure the bottom end of the zz4 is strong enough except for the pistons
What are your thougths to achieve 600 hp with the zz430
Old Oct 7, 2003 | 11:14 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I would suggest the GM injection system that could be gotten for one of those babies and then the supercharger. You could use the 749 ECM that is very popular here. In that way you could keep the economy (or better) and control the spark more safely to defend the pistons.
Old Oct 7, 2003 | 08:57 PM
AustinT's Avatar
I called smeading in California to get a price on some engine work. They reccomended putting some bigger valves in the fastburn heads. Is this really needed with a supercharger? Cant you just turn up the boost to overcome this?
Old Oct 7, 2003 | 09:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
flow in a boosted motor is just as important as in a NA motor. I dont feel the valve work is needed to achieve your goals.
I feel if you are going to open that can of worms you may as well go through the motor and add forged slugs.
Old Oct 8, 2003 | 01:08 PM
AustinT's Avatar
Thanks for the reply,
Can you comment on the bottom end of the zz4 block. Are the rods OK? IS the hot cam a good canidate for a supercharged motor?
Old Oct 8, 2003 | 01:27 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
no it is not, it can generate excessive amounts of cylinder pressure.
Old Oct 8, 2003 | 02:54 PM
AustinT's Avatar
Your talking about the Cam right. What makes it not a good supercharger Cam? 218,228 112 lobe seperation I think these are the specs
Old Oct 8, 2003 | 03:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
dont get me wrong its an awsome cam but not for supercharging here read this
https://www.thirdgen.org/techbb2/sho...postid=1148061
Old Oct 8, 2003 | 04:08 PM
AustinT's Avatar
Thanks, Almost seems like it would be easier to forget the zz430 and start over?
Old Oct 8, 2003 | 06:14 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
hmm I can say the ZZ430 wouldnt be my first choice for this but then again if you do go with the EFI or just add the EFI hardware and run a ECM made for our cars, then you could get say like thebasemodel P1sc kit made for our cars with regular intercooler and no changing cams or piostons and see what happens.
Old Oct 8, 2003 | 07:03 PM
AustinT's Avatar
Could I do the same only using a carb bonnet. Im not really scared of loosing mileage. I get 22 mpg with the holley carb,
Old Oct 8, 2003 | 07:09 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You'll have to do some modifications to the carb for a flow thru application. Also, it's harder to tune a flow thru system than a pull thru system like a roots blower.
Old Oct 8, 2003 | 11:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
and the fuel system for a blow through needs to be nearly like a EFI fuel system
Old Oct 29, 2005 | 02:06 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
As far as the valve work they suggeste goes, were you clear (or did they understand) that you have the ZZ430 which has FastBurn heads? They might have ZZ4 and stopped listening at that point.... if that's the case, I could see the valve suggestion because then they are under the impression you are using ZZ4/L98 aluminum heads
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
