Gotta love the cold weather!
Old Oct 30, 2005 | 10:54 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Been working on my intercooled YSI combo since the summer and it`s really coming around.I started out running the same on 10# of boost as I did on a 150 shot of nitrous,10.30s@ 131 or so mph on 93 octane,last month put some c16 in the tank and fed it more timing resulting in 10.0s/teens at 135/137.On the 27th went racing again in the coolest temps so far this year and WOW......142.29 mph No change in tune-up just awesome air.My intake air temps usually peak at 150* with boost at 10# at shift points,barely got over 100* and boost went up 2-3 pounds.
Blew the tires off on the hit,1.59 60`and went 9.98 at 142. Last pass of the evening got some bite,1.37 60`,6.20@112 in the eighth,9.87@114 in the quarter.Drove thru a poorly cleaned up oil spill at 1000`got way loose and had to lift.I`m going again on the 5th to try agian,then that`s it for this year.Need the rest of the cage installed and a Little M as my GM 400 block will not put up with this level of power. I`ll post up the results.
Later,
Glen
Old Oct 30, 2005 | 05:50 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
what kind of power do ya think you've got there?
nice times
F-body-fan
May 4, 2026 09:42 AM
Veaceonee
Sep 29, 2016 08:15 PM
timonator
Sep 30, 2015 12:52 PM
ramicio
Sep 28, 2015 01:18 PM
david068513
Sep 18, 2015 10:36 AM
