Yes, the F1 DOES bolt onto the P1/D1SC Bracket!!
Old Oct 28, 2003 | 06:11 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
For all those who've wondered if this is a bolt-on replacement, here's visual proof!! Just bolted it on. The case appears to be identical in size.... The internals are another story.... now, for some fun!
Attached Thumbnails Yes, the F1 DOES bolt onto the P1/D1SC Bracket!!-f1-03.jpg
Old Oct 28, 2003 | 07:00 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
wow nice, any more pics? also how did the biuld of the 4 bolt main 305 you had done go?
Old Oct 28, 2003 | 07:25 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
SWEET!
Old Oct 28, 2003 | 08:09 PM
Willie's Avatar
Very well. It now has about 800 miles, enough to stuff the blower back under the hood. The final steps in my project involved converting from the 165 ECM (MAF) to the 749 (SD with 3-bar MAP). Because very few have accomplished successfully a 749 with a 3-bar, I'm going to take an intermediate step and use a 2-bar to get it tuned to 15-psig boost. Then, the plan is to experiment with the 3-bar and "go where no one has gone before"....
Willie
Old Oct 28, 2003 | 08:38 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Old Oct 29, 2003 | 03:26 PM
MdFormula350's Avatar
awesome!
I am saving for the ATI P1SC kit, i am almost there. might be a great chirstmas after all :hail:
Old Oct 29, 2003 | 04:59 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
So I assume that If somone was to purchase a P-1SC then decide later to shoot for the D-1SC they could just purchase the head unit itself, and keep the rest?
is the pipe size and routing identical as well?
Old Oct 29, 2003 | 05:31 PM
Willie's Avatar
Yep.
Yes, it is. There could be on difference though. The no-cost intercooler with the P1SC kit is the 2-core. The 3-core is optional. And through the right sources, my twin hi-flow design is also available as an option. The D1SC kit comes with the 3-core. Again, the twin system is available.
If you start out with the P1SC, you might as well upgrade the intercooler. My suggestion is to use the 3-core if you live in cool weather climates where summer heat is not an issue. Definitely go with the twin setup in warmer climates as the 3-core does interfere with engine cooling significantly.
Willie
Old Oct 29, 2003 | 11:21 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
I think florida qualifyes?? Ill have to re-read the post on your twin-high flow setup. it has been a while...
Old Oct 30, 2003 | 06:49 AM
Willie's Avatar
Definitely. I know "mypontiac" installed the D1SC kit with twin hi-flows. Through Dave Back at Tenacious Performance, he was able to substitute the twins in lieu of the 3-core for no extra cost. BTW, he lives in New Orleans (similar weather to Florida).
Willie
Old Oct 30, 2003 | 11:45 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
willie one other question.. the F1 i understand is a bigger badder supercharger than even the D1SC, but is there any drawback to having it instead of the D1? make less boost down low? worse for street cars? Im pretty sure the D1 would feed my 383 12-15 PSI but its always good to have the backup boost in case you just have to hit the 10's or somthing sick...
Old Oct 31, 2003 | 01:36 AM
CrazyHawaiian's Avatar
Car: too many ...
Originally posted by Willie
[B]The final steps in my project involved converting from the 165 ECM (MAF) to the 749 (SD with 3-bar MAP). Because very few have accomplished successfully a 749 with a 3-bar, I'm going to take an intermediate step and use a 2-bar to get it tuned to 15-psig boost. Then, the plan is to experiment with the 3-bar and "go where no one has gone before"
Sounds like a good plan! This is eventually what I would like to do, but it all depends on how much boost I can actually push. My supercharger is rated to handle 20psi, but alot of people have expressed problems with belt slip at high boost levels. I've heard the solution is converting to cogs, but I dont have any experience with this yet. But anyway, the solution seems to be going with the stock 749 2 bar MAP, and if I am able to push more boost later, then upgrade to the 3 bar and re-tune. The real crappy part about this (unknown end result boost levels) is how hard it makes it to choose injectors.
As for the intercooler, I've been thinking about a creative way to use the 3-core and not affect cooling (important to me because I live in Hawaii). I'll need to make some mock models to check for clearance (both for the IC and the piping), but I might be able to get it to work. If it dosnt work out, then I will end up going with your (very good I might add) twin design. I want to try something really unique first.
Old Oct 31, 2003 | 08:23 AM
Willie's Avatar
....is there any drawback to having it instead of the D1? make less boost down low?
There are two primary differences between the D1SC and F1. The F1 uses a "stacked" set of roller bearings, which allows it to rev another 10,000 rpm, up to 70,000 (the D1SC can be revved safely to 60,000) and the 5.0 to 1 internal step-up ratio (D1SC is 4.1 to 1). This means more boost sooner and has a higher limit. Therefore, it will not make less boost down low, it will make more.
I guess I'm about to find out. I don't feel it's worse at all. I think it's going to be better!
I agree with you. The D1SC is more than capable of filling a 383's cylinders with 20 pounds of boost.
And in my case, I know I'll be pushing more than 15 pounds. I was at 14 with my D1SC at 6,000 engine rpm's with a 12-rib pulley combo which was driving the blower at 55,000 rpm's, but there was some slippage. My current cog combo, at 6,500 engine rpms will give me 69,000 impeller rpm's. How much more boost will that equate to? Only time will tell. I do know for at fact that Larry at ASSC runs the F1 on his daily driven 350 Formula and he manages 26 pounds at 6,000!!!!
Do a search on this board on cogs. I've written some about my experiences.
I hear ya. I feel the only way to size injectors is not by boost levels, but by maximum horsepower output. There are tables based on hp and BSFC that are used to determine injector size.
As for the intercooler, I've been thinking about a creative way to use the 3-core and not affect cooling (important to me because I live in Hawaii).... I want to try something really unique first.
Sounds good. I like to be unique too.
Willie
Old Mar 18, 2009 | 12:46 PM
mr-zr's Avatar
Re: Yes, the F1 DOES bolt onto the P1/D1SC Bracket!!
search for cog kit to my camaro. some tips were can bay it? //micke
Old Mar 18, 2009 | 01:39 PM
Beater79TA's Avatar
As was recommended in the other thread, call Larry at ASSCRacing (www.asscracing.com). He makes the cog kit for our cars. It might not be listed on his website but he does have a kit so if you don't see it, call him to ask about it.
Old Mar 19, 2009 | 05:20 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If I'm not mistaken ******* crank cracked................
/N.
Old Mar 19, 2009 | 08:14 AM
AC's Avatar
AC
Car: Used to drive a camaro
GTA, you're right, his crank did crack. I just saw an interesting line under his sig too.....2008 Shelby GT500 ?? He went to the other side!??!?!
Old Mar 19, 2009 | 10:54 AM
Beater79TA's Avatar
I seem to remember something about the crank breaking... Wasn't it related to a manufacturing defect in the crank more than the use of the cog drive on the F1A?
Old Mar 19, 2009 | 11:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
spinning a F1 @ 70000rpm and engine break will put some stress at the crank snout.......... I would consider the "special" pulley I posted in the other thread for streetuse............
Old Mar 19, 2009 | 11:42 AM
mr-zr's Avatar
yes im know.. but need crank pullet and drive belt and more.. :P im have take your tips on that pulleys..
Old Mar 19, 2009 | 12:02 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
what kinda crank did he use and was it forged???
Old Mar 19, 2009 | 01:05 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
This thread gives details of the specifics of the crank breakage.
https://www.thirdgen.org/forums/powe...xperience.html
Old Mar 19, 2009 | 04:09 PM
tom86iroc's Avatar
Car: 1986 iroc
ok thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
