Difference in nitrous carb plates?
Old Nov 25, 2003 | 10:06 AM
96-speed's Avatar
Anyone have any advice on carb plate selection for a Vic Jr manifold? Would the fact that the manifold is converted to EFI have any effect on nitrous plate selection?
I'm new to plate setups .
tia,
Ryan
Old Nov 26, 2003 | 08:22 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I used the cheater plate (a super powershot kit) with the TPI system (5151) jetting to run 11.90's at 5800 foot altitude
Old Nov 26, 2003 | 11:11 PM
stevedave454's Avatar
Car: 91 S10
assuming thats its standard squarebore bolt pattern any squarebore plate system will work, but like b4ctom said, if your running fuel injection you will have to get the right jets, because if you jet it for 100 hp at 6 psi but then hook up 45psi to it you will run very rich
customblackbird
Aug 15, 2021 10:16 PM
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
