144 short with stock serpentine set up pic
Old Dec 25, 2003 | 08:38 PM
89rs/sc's Avatar
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
this is my 89 rs with a 305 . i used ashort snout for use with the short pump and spaced the s/c and tensioner pulley out 1/8th f an inch i then used under drive pulleys due to the fact that the ubderdrive crank pulley is roughly the same size as the s/c pulley,ive been using this for 2.5 years now without a problem
http://www.msnusers.com/l5rdohe4so6b...ebay%20052.jpg
Old Dec 25, 2003 | 09:17 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
All i get is the red x
Old Dec 25, 2003 | 09:22 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
me too
Old Dec 25, 2003 | 09:31 PM
89rs/sc's Avatar
Car: 89 rs
is it working now? it seemes to be a pic on my end??????????/
Old Dec 25, 2003 | 09:32 PM
Engine: 383, L69
nope still not for me
Old Dec 25, 2003 | 09:41 PM
89rs/sc's Avatar
Car: 89 rs
can you see it now!?
Old Dec 25, 2003 | 10:01 PM
biggtime's Avatar
Nope!
email me the pic I will post it.
Old Dec 25, 2003 | 10:03 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
that red x sure looks great.
Old Dec 26, 2003 | 02:26 PM
biggtime's Avatar
here you go
Old Dec 26, 2003 | 02:32 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
schweet
how big of a cowl hood do you have to run to clear it?
Old Dec 26, 2003 | 05:26 PM
jon_volk's Avatar
anymore pics than that? a few diff angles maybe?
Old Dec 26, 2003 | 05:45 PM
89rs/sc's Avatar
Car: 89 rs
i do have more pictures but it seems i cant publish the pictures to this site,biggtime posted this one for me,thanks again! email at rory@net2music.com it sais you live in milfor, i live in danbury...
Old Dec 28, 2003 | 10:12 PM
xpndbl3's Avatar
Car: 1984 Z28
e-mail the pics to me and i'll post them to this link
Old Dec 29, 2003 | 09:41 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Looks like a 4" cowl would be needed to me, at least 3".
Old Dec 29, 2003 | 12:33 PM
xpndbl3's Avatar
Car: 1984 Z28
ok here's the pics....
Attached Thumbnails 144 short with stock serpentine set up pic-89-rs-001.jpg
Old Dec 29, 2003 | 12:34 PM
xpndbl3's Avatar
Car: 1984 Z28
pic #2....
Attached Thumbnails 144 short with stock serpentine set up pic-89-rs-003.jpg
Old Dec 29, 2003 | 12:47 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
hmmm
he probly doesnt have a problem right now, since hes been running it for awhile, but IMO i would run a idler pully between the blower and alt so that theres more wrap around the blower......
like this:
Attached Thumbnails 144 short with stock serpentine set up pic-blowerfrontpic2.jpg
Old Dec 29, 2003 | 06:09 PM
89rs/sc's Avatar
Car: 89 rs
YEA I DO AGREE ABOUT THE IDLER, AND I CONTIMPLATED USING ONE BUT THERES REALY NOTHING TO MOUNT IT TO, AND AS YOU SEE ROOM IS AN ISUE, AFTER I GOT IT TOGETHER AND REALIZED IT DIDNT SLIP,I DIDNT WORY ABOUT IT, ITS HAD THE SAME BELT FOR THE PAST 2 YEARS AND 7500 MILES. OH BY THE WAY IM NOT YELLING I JUST LEFT MY CAPS LOCK ON BY MISTAKE....
Old Dec 29, 2003 | 06:14 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
hehehe i was gonna say.....
its reassuring to hear it doesnt slip with the belt like that.... currently thats my big fear with the M112 im putting on my car...
i wanted to do somthing like i have below, but im cutting it so close on room, i donno if im going to do it or not....
i just dont want it to slip excessively or throw the belt.
Attached Thumbnails 144 short with stock serpentine set up pic-02_lightning_engine.jpg
Old Dec 30, 2003 | 11:58 AM
Damon's Avatar
You already HAVE an idler pulley. It's just not in a very convenient place. Maybe there's a way you could rotate the whole "guts" out on the front of the snout. I thought about just unbolting the snout from the blower case and rotating the whole thing but then it won't clear the thermostat housing. This might be easier than a whole separate idler pulley.
Old Dec 30, 2003 | 12:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
hehe, you can have more then one.
we're talking about adding another point, so that the amount of belt surface the blowers pully increases...
if you look at the ford lightning motor i posted, you'll see that they take this to the extreme and use two idler pullys in such a way that they get the most wrap around the blower pulley as they can.
all belts slip a little.. that one of the reasons they wear out... but if you can reduce that amount, the belts last longer, and with more area around the pully, theres usually less of a chance of tossing it too.
but he says he has 7500 miles on it without a problem, so in this case, its a non issue......
Old Dec 30, 2003 | 01:21 PM
biggtime's Avatar
It must not be making that much boost. i am thinking somewhere around 5 lbs? If he trys to run more you know its gonna slip.
Old Dec 30, 2003 | 04:29 PM
89rs/sc's Avatar
Car: 89 rs
yep, only running 6 psi of boost, and your right, change the pulley ratio to make more boost and it might have more of a chance to slip, like i said, i did reserch on putting a stationary idler but i just never needed it,i even thought about flipping the tensioner but too much hassle, remember this is a stock 62000 mile bottom end ! dont want to get too nuts with this power plant,when it does start to knock and or leak (coolant or oil ) i will probrably build a mild 350 with a stout bottom end and forged pistons . i believe the tbi 305 has 9.3 to 1 compression so 6 psi is enough, on pump gas (93) i am running only 30 * of total timing,which is great but like i said thats only with 6 psi......now im going to have to pull my tranny in the next few months due to the tipical 3rd gear clutches going bad ( 2nd to 3rd shift flare up ) ......not bad for a 700 r4 to go 62000 miles ! and just now starting to fail, when i worked for gm we were replacing these trannys at about 19000 miles.!! im gonna shut up now i just keep ramblin on
Old Dec 30, 2003 | 06:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you run it in the 1/4 yet? or the 1/8th? dyno?
im just curious how much more power you have with that on a stock 305...
Old Dec 30, 2003 | 09:25 PM
89rs/sc's Avatar
Car: 89 rs
13.89 at 98 mph, i ran it last in 2002 its not completely stock i am running it through the edelbrock tpi headers with a 3 in hooker cat back, comp cams 214/224 443/465 b&m trans pack with 2500 stall converter. the supercharger definatley woke it up. originaly i had this set up without the s/c running an edelbrock tbi performer and a holley throttle body, ran better but still was piggy.....went carb with a performer, better at high rpm but lost some bottom end feel , then s/c ...big difference that time was 7 months after i first installed it, that was with the stock 2.73 open rear, i ve been busy the past year building my 76 vega coupe with a aluminum headed 357, so most of my time/money has been going to that project. so i havent ran it with the 3.73 and so/so gov loc..... this summer though.......
Old Dec 30, 2003 | 09:57 PM
zerotosixtyV8's Avatar
Car: Camaro
is that 13.89 on a stock headed 305??? You could get a HUGE gain if you went to aftermarket heads
Old Dec 30, 2003 | 10:05 PM
89rs/sc's Avatar
Car: 89 rs
yea thats with the stock heads, problem is is that aftermarket heads on a 305 are not that great,ive seen the 305 tourqer s/r good head but for what this car is, i wouldnt spend the money, due to the small bore of the 305 most aftermarket heads will not work unless you notch the cylinders....not on all but on some, then you run into the large chambers that are for the larger bore 350 which could put compression down to 7.1 not a bad thing but not what i would want with a low pressure s/c like i am running....i cant wait to see what my times will be like this spring with the 3.73 and posi, the last time at the track proved to be a smokey experience
Old Dec 31, 2003 | 02:44 AM
Car: Camaro
true, it is a limited selection, but I can tell you I'd almost guarantee you'd shed a second going to even L98 heads. those TBIs are just that bad lol. still not bad!
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
TheExaminer
Aug 26, 2015 04:59 PM
jahblah
Aug 12, 2015 05:54 PM
