what are your 1/4 mile times and setups
Old Jan 1, 2004 | 11:05 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
yes i did a search but i am realy looking into power adder only runs, no2 runs and na runs off the gas. thanks guys and how hard was it to get you car not to smoke em off the line?
Old Jan 1, 2004 | 05:25 PM
Friday128's Avatar
Car: 88 RS
Engine: some what of a 350
Transmission: dont got one
to get a good run with Nitrous
you wait until AFTER you get off the line to hit the button
so i know in a probe you wait till about half way through 1st and you hit it then you hit it again in 2nd or 3rd if you want
but they do make system that when you floor your car it adds nitrous to the mixture so that could be a possibility for you
Old Jan 1, 2004 | 07:43 PM
c4boom's Avatar
Engine: l98 and lo5
ya i know how to run it but what i was talking about is how do these guys with TT setups and monster HP get down the track how do they set up for it what works what is a wast of money.
Old Jan 1, 2004 | 08:32 PM
rustbird's Avatar
Car: 92 firebird
Engine: A small block something?
I have a freind that lives in chicago with 68 camaro w/377 sbc on a 400 shot that cant hook right unless he sprays it directly out of the hole he has wrinkle walls and they "crackle" when he sprays it.
off the bottle he spins because there not a "shock" to the tires.
I guess it all depends on your suspensoin and what kinda rubber your on.
Old Jan 2, 2004 | 10:03 PM
c4boom's Avatar
Engine: l98 and lo5
so no wone running a good motor with big boost is willing to share there setup. is that due to the fact that they boot you of the track after one run.
Old Jan 3, 2004 | 07:40 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
combo in sig with new one will be looking for bottom11's maybe tens on high boost. might wanna see if a pt51 could do it!
Old Jan 3, 2004 | 09:58 PM
c4boom's Avatar
Engine: l98 and lo5
thank you dang thats quick out of a 6
Old Jan 5, 2004 | 08:56 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
89 GTA 3.8 Turbo stock block, crank, rods, heads(ported), intake(ported) with JE pistons. TE64 turbo, 55# injectors, bigger intercooler, and a little cam(214/210@.050).
TH400 trans with brake stalls 4200rpm@20psi
12 Bolt with 3.08 gears running 26x11.5x16 ET Streets on stock GTA wheels(stock wheels up front too w/245/50R16)
3550lbs weight with me in it
10.69@125.8 with 1.47 60ft
Old Jan 6, 2004 | 03:23 AM
TA88GTA's Avatar
^^^ how much boost were you running???
Old Jan 6, 2004 | 07:05 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Its kind of the same as with any fast car... Sticky WIDE tires, good springs struts, LIGHTened front end, full spool, plus in my case rod end control arms and PH rod, lca relocation brackets, adjustable torque arm sitting slightly heavy on the pinion angle, and a VERY solid wolfe racecraft swaybar...
Ive yet to make any passes on the current setup..Guido did when he had the setup and he launched fine...
Old Jan 6, 2004 | 08:32 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
12.45 on a 100 shot. Depending on the track she would hook the 551rwtq out of the hole. But it had to be preped real well. That was on DR's so it would've dead hooked all the time on slicks, and probably would've went 12.0 but that was the old motor.
It depends on your suspension. That's what will determine if you're going to hook or not.
Old Jan 6, 2004 | 11:23 AM
83 Crossfire TA's Avatar
Torque has almost nothing to do with how fast a car will run, just what combination of driveline parts it will take to run the fastest. Almost all sprayed cars will throw up insane torque spikes then the N2O is turned on, which is not really useful at the track since most people don't hook there and if they do it just makes for a more violent ride which is more likely to break parts. The reason being that you're adding almost exactly x hp worth of air/fuel when you flip it on, so with a 150hp shot that you turn on at 2800rpm that's a 281lb-ft torque spike… The second reason is that suddenly applying 2-300lb-ft of torque always spins the tires on the rollers and they have to accelerate faster to catch up and stop spinning once that happens then the tires are really accelerating, causing a spike in the curves at that point.
Old Jan 6, 2004 | 12:35 PM
BlownBird's Avatar
Completely stock shortblock, trans, and rear... sticky tires, and 21psi from a Vortech Y/S-Trim.
Best run to date 10.08 @ 144
Old Jan 6, 2004 | 02:49 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
26-27psi on Sunoco 116 octane I was out of fuel with my 55# injectors at 27psi. Going to 83# injectors for 2004
My best times on pumpgas(Sunoco 94)at 20-21psi is 11.46@115.81 with 1.55 60ft and best mph is 11.49@117.80 with 1.68 60ft
Thats impressive I think though your tires are not sticky enough.With that mph I'd be looking to be in the 9.4-9.5 range.What kind of 60ft?
Steve
Old Jan 6, 2004 | 03:23 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Set-up and times within
https://www.thirdgen.org/techbb2/sho...hreadid=175272
Old Jan 6, 2004 | 04:12 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
The 51 should be able to do it. I was running 120-121mph with the Thrasher in there but was pig rich on the bottom and couldn't build any boost. 11.82@121.4 on a 1.87. With the turbotweak chip, I can launch but can't make the 3rd gear pull the Thrasher has. 11.61@115.7 on a 1.62.
93 octane and alky injection
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Street Lethal
Aug 13, 2015 08:28 PM
