Megasquirt is becoming a contender!
Old Jan 31, 2004 | 09:37 AM
a73camaro's Avatar
MS is in Car Craft.
Car Craft
Old Jan 31, 2004 | 08:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah I saw that it uses on "on board" MAP that has boost enrichment capabilities.
Old Feb 2, 2004 | 06:23 PM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
anyone here ever used it...has a friend that used it? could this be rigged as a supplemental fuel injector like the superfueler etc? I acctually like it and building my own computer just adds to the hands on factor to me.
Old Feb 9, 2004 | 04:52 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
actually yes. It runs speed density but it has a map that is sensative to 2 bar which means it can replace your whole system similar to the 749 swap. it can be programmed to add fuel under boost.
Old Feb 9, 2004 | 09:39 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
87F383:
check out my posts in this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=218203
Im planning on using it to tune the setup im currently working on: twin turbo with .60/.63 t-3's. I have to upgrade to the 2 bar map sensor, because I bought the very first version that only came with a 1 bar map. Ill let everyone know how it turns out.
Old Feb 9, 2004 | 01:38 PM
mettalicirocz's Avatar
Car: 1986 camaro, 1993 nissan altima(winter beater, 1992 mustang (summer daily driver)
Engine: 350tpi
Transmission: 700r4 with shift kit
what does it cost to setup and how hard is it to tune anyone know??
Old Feb 9, 2004 | 01:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes read the article it has costs, but make sure you redo thier math because they bought a pile of useless stuff like SLP runners $279, injectors $460 for this project car. I think in the end you can get into one for just under $400
Linson
Oct 24, 2025 02:00 PM
85Special
Sep 3, 2015 04:21 PM
Thirim
Aug 13, 2015 03:09 PM
Tricked-Out-Toy
Theoretical and Street Racing
Nov 30, 2005 11:46 AM
86bird_28v6_5spd_ramair
Aftermarket Product Review
Oct 13, 2001 09:57 PM
