Vaccum needed!!
Old Feb 2, 2004 | 09:54 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Vaccum needed!!
Hello,
Please see sig for motor mods, I have a ATI Blower so at normal driving I have about 14-16 of vaccum,however when it drops to 5 or less or even when I am in boost the dash vents close and all the air blows from the defrost vents. Can someone give me suggestions on how I can fix this. Any and all information will be greatly appreciated.
Brad
Old Feb 2, 2004 | 11:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you need an industrial check valve between the accessory vacuum can and the intake.
Old Feb 3, 2004 | 06:38 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
84Ctom1,
First I want to thank you for the info. I am still confused a bit. I dont have a vaccum can., I had a small round plastic type, which I believe was used for the cruise control.
Where can I purchase this industrial check valve?
Brad
Old Feb 3, 2004 | 10:01 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
That can was used for cruise AND for the Vents... If you removed itthen thats your probem....
Old Feb 3, 2004 | 10:52 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Now that I know the problem, what is the proper way of hooking the can up? I think its like this: input to can is the intake, output of can goes to vents.
Old Feb 3, 2004 | 11:47 AM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
LOL It was sooo long ago that I removed mine that I cant exactly remember...
But I thought that the canister had 1 line TO IT....then there was a wierd check valve that TEE's into that line....one side of the line went to the HVAC system the other to the manifold....
But again Im going on rusty memory...
Old Feb 3, 2004 | 03:03 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
LOL, I sure hope some one can help me. It's been a long time for me too, guess I might have to go to junk yard to look at some birds, however I hope someone may post some pics for this old man who has a bad memory!!!
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
