Could my engine handle Nitrous
Old Feb 4, 2004 | 05:03 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Here are my Engine Specs
350 Bored 30 over
Flat Top Pistons
Steel Crank
Double Bump Heads
All new Gaskets
Seats, Rings
2600 Stall Convertor
Turbo 350 Tranny
Stage 2 Shift Kit
3.23 Rear end
Engine is pretty much new from the rebuild, has maybe 5000 KM on it since the rebuild. The engine is the older carbed, 1967-73 I believe.
I only want a 50-75 shot. Whatta think?
EDIT: I forgot the Compression is CRAZY high in her too. Dont know if that matters
Thanks, Joe
Old Feb 4, 2004 | 12:47 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
the heads you have are 64cc,with flattop slugs depending on deck height,gasket quench,milled heads you should be in the 9.8-10.5 area,if you are not certain on the type of piston you have(forged or cast)i would not go higher than 100hp setting with the fuel pressure on the nitrous set at 6-6.5psi.nothing less!!!!!!only use the nitrous ABOVE 3000 rpm.......
Old Feb 4, 2004 | 03:11 PM
Daishi's Avatar
Yeah forged pistons, its 4 bolt main too
Old Feb 4, 2004 | 03:13 PM
PhilM's Avatar
Car: Accepting applications...
it would probably handle a 200-250 shot with the right fuel and tuning, but a 50-75 shot would be like nothing to it.
Old Feb 4, 2004 | 05:50 PM
gen3z's Avatar
:werd:
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
