I'm confuzed
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
I'm confuzed
Ok most people say not to add boost to a engine with 10:1 compression, well wouldnt it be better to have a NA engine running 10:1 compression, then adding boost??
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
It is the dynamic compression that is important. If the dynamic compresson is too high then you need higher octane fuel to stay out of detonation problems.
A big cam will give you lower dynamic compression.
Higher static compression will give you higher dynamic compression.
That is why you use higher static compression on an engine with a big cam.
Boost will also raise the dynamic compression. That is why you need a lower static compression to compensate.
i think hes asking what the point of boosting an engine if you have to lower the compression rather than just running a 10:1 n/a motor.
the reason simply put is airflow. think of it as increasing the displacement of your motor by forcing twice as much air in.
Car: 1984 Corvette
Engine: Turbo 350
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Confuzed1
Nov 23, 2012 08:09 AM
Confuzed1
Jun 17, 2012 09:55 PM
