water injection
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
water injection
wondering if any of you guys use water injection. i have an N/A engine but would still like to use this. Im just posting here because most people use water injection so they can run more boost. but im having trouble because most water injection is run of a manifold pressure switch. and i dont have pressure i have vaccume. any ideas on how to control a pump depending on rpms?, or load? thanks
Walter
Walter
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
water injection actually should do a lot for an N/A engine. it should increase efficiancy gas milage, and help it to run cooler, and i will be running pretty high compression, and it should allow me to advance timing without any spark knock
thanks for the infomation
Walter
Walter
Try it, it should work but I don't know anyone who's done it.
In theory you should be able to run more timing/compression on **** gas (which may help also since quite often 87 octane has more energy in it then 89 or 91-94). There would be much simpler ways to do it but if I was going to waste my time with it I'd probably go completely wild to it and trigger it off the/a map signal, so when it turns on and how much you get would depend on load. You could accomplish something very similar by using the TPS sensor signal, but in either way you'll have to figure out how to activate it at a specific voltage (which is what makes it slightly more complicated).
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
you can run it off an RPM window switch, but unless your running really high compression it'll be useless for you
-- Joe
