fix up an Ironduke
Old Feb 26, 2004 | 08:52 PM
Aqua FBody's Avatar
Car: 95 Contour GL 03 KIA Spectra
Engine: 2.0 Zetec 1.8
Transmission: MTX-75 5spd
fix up an Ironduke
I was looking at my buddies Camaro and his Ironduke were wondering how taboo it would be to put euro type parts on such as a nice exhoust NOT a fart can, a turbo, a hood scoup, a wing and maby a few more things. Thanx for the input.
Old Feb 26, 2004 | 09:34 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
why would u put a wing on it?
Old Feb 26, 2004 | 10:41 PM
Aqua FBody's Avatar
For looks
Old Feb 27, 2004 | 01:22 AM
83 Crossfire TA's Avatar
Man, don't **** out an f-body. WRT to wings and things… if you need them, great, otherwise leave that crap off. For example, Guido's old camaro NEEDED the aluminum wing that it had (probably, if nothing else I would imagine it helped stabilize things at the top end and with the deployment of the 'cute).
With the Iron Duke… go for it. I've always wanted to do it. There are a lot of rather cool and somewhat arcane parts out there, as well as some fairly standard performance parts that will work in them (I know for a fact that SBC 350 pistons will work and possibly rods, so there you have a cheap source of quality pistons…). They actually have a surprising amount of build up potential. I've seen relatively mild, streetable NA examples that are good for about 200hp, and I don't see any reason why you couldn't get a supercharged (turbocharged) one that was built up right into the >300hp range without spending big $$$.
You could end up with a really unique/cool setup… I think it would be pretty wild to be able to blow the doors off of your average 12-16second v8 f-body with half the cylinders under the hood.
Old Feb 27, 2004 | 09:21 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
It would be cool, without an aluminum wing. If you want a spoiler, go with a 91-92 high rise or something. A 5" 3 piece would look real good too. I say go for it.
Old Feb 27, 2004 | 10:15 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Now I think your stretching the word needed, as his car didnt need the wing and that was probrobly the only mod he did that I didnt like.
Now I'm not sure exactly how fast that car would have gone, but know several cars running similar turbos in the mid 8's and know another with twins running 7.85@176 with no wings(or exterior body modifications what so ever).
Steve
Old Mar 1, 2004 | 06:58 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I had a iron duke in my boat until it blew a head gasket. The boat model uses a v8 bellhousing. It uses 350 pistons and rods.
I went to a 350 in my boat, because I couldn't find another iron duke block with the v8 bellhousing.
Iron duke carbed was 140hp. 350 is 260hp.
-- Joe
Old Mar 1, 2004 | 12:03 PM
Aqua FBody's Avatar
What is the CID of that Iron Duke anyway
Old Mar 1, 2004 | 12:55 PM
Why didn't you just put a new gasket in it rebuild it? Should cost about 1/2-2/3 of rebuilding an SBC (many of the parts can interchange, but you only need half of them and half the machine work), and it can be done rather cheaply.
For future refrence if you need an SBC bolt pattern the fiero guys have adaptor plates for fairly reasonable prices.
Old Mar 1, 2004 | 11:27 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why did the head gasket blow?? I know the valves got rusted really quick. Ya know what, I sold the block and repowered with a complete v8 setup (out of a crate).. I even changed the outdrive.
I'd rather have 260hp in the ocean than 140hp personally.
-- Joe
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
