What can i give this 327
Old Mar 22, 2004 | 06:49 PM
KillerRS's Avatar
I have a 327 with billet crank, lt1 pink rods, and speed-pro forged .40 pistons. and a 4 bolt 350 block. i plan on running my vortec heads stock mill witch will give me a cr of 10.5:1. i know you should run a low cr for forced induction, but is 10.5:1 low enough for a turbo or should i use nitrous.
Old Mar 22, 2004 | 10:27 PM
stevedave454's Avatar
Car: 91 S10
keep boost under 10 psi, have a very efficient intercooler, and water injection and you should be ok... also make sure you have a very good tune
Old Mar 23, 2004 | 12:53 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
No it's not low enough.
Old Mar 24, 2004 | 12:30 AM
KillerRS's Avatar
yeah i dont want to keep it under 10 psi, i have read billet cranks are the best you can get, if it comes to replacing the pistons it wont bother me much, i got the shortblock, unused still in bags and boxes, for free. I would like to make 550 hp to the flexplate
Old Mar 24, 2004 | 05:40 PM
KillerRS's Avatar
anyone else
Old Mar 24, 2004 | 08:34 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i like boost but in your case nitrous would be better. You have a bit too much c.r. for boost on pump gas
Old Mar 24, 2004 | 09:33 PM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
Water injection is sort of like a temporary fix in my opinion.
10.5 plus any boost even with an intercooler will probably not run on pump gas. I could maybe see it if it were low as in 6-8psi and tuned accordingly.
Nitrous will save you some money and make the power you want.
I vote nitrous!
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Linson
Oct 1, 2015 09:50 PM
