upgrade! need help please
Old Mar 25, 2004 | 09:54 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
k i need help i want to get a new cam that will give me the most power with my setup??
1983 Z28
this is the setup so far>(as i no)
70s 350 block (dont know if heads have been changed and dont know present high lift cam in there or if anything else is done so i am starting over because of this and other issues...anyway..
rebuilt 1 week ago th350 with shift kit
new 2200-2500 stall converter
roller rockers
no smog crap
new 3.42 gears
holley intake>>(dual plane, ither Idle-4800 rpm or Idle-5500 RPM power band, dont remember sry.
holley 750 vacuum secondary>(thinking of putting a holley 650 DP)?
accel egnition and wires
headers
3" exhaust
flowmaster muffler
high flow cat
i want to be in the 13s by 2 months, so tell me what i need to do/get??? PLEASE!
i have 255/40zr17 tires and roh snyper rims, fiber glass hood, i still have a mechanical fuel pump thats new and old stock fan, a k&n open element if any of this helps.
Old Mar 26, 2004 | 01:00 AM
83 Crossfire TA's Avatar
1- why did you post this in power adder?
2- the car should run better then 13's assuming that everything you have now is well matched...
Old Mar 26, 2004 | 11:15 AM
Car: 1983 Z28
Transmission: TH350
i dont no> i want power and want a new cam and a cam brings power sry if this is the wrong place(were is this post suppost to go then??)
i have not had my car to the track yet or ever for that matter so i dont even no what 13 or lower feels like to say, all i no is she aint slow lol. its running perfect now and feels really fast i just want to get everything i can get, and know everything in my engine. so what cam would be the best for this setup? i want everything to work togeather and match.
Old Mar 27, 2004 | 12:36 PM
Car: 1983 Z28
Transmission: TH350
wow that sucks no one knows! anyone??...please lol
Old Mar 27, 2004 | 05:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
don't take this the wrong way. Im just looking to help keep your thread from being locked by keeping it power adder oriented and by answering our request. Turbos, centrifugals, and roots superchargers all are safe when used safely and in moderation, that goes for THIS as well. If you get this you might want to consider one of THESE just for it separately with a regulator and leave the pump you have now for the carb by itself.
Old Mar 30, 2004 | 10:47 AM
Car: 1983 Z28
Transmission: TH350
thanks for the help, and sry mods for putting this in the wrong spot. B4Ctom1>thanks for the info.
Old Mar 31, 2004 | 03:07 AM
Maybe try general engine...
But like I said, that assuming that everything is done right you should be going a lot faster then 13's... I've run a 13.5@100 with essentially a stock L98 with no real changes besides a cold air and cat back...
You've got a somewhat modified engine, converter, gears... You should be going faster.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
