LT1 TNT install question
Old May 10, 2004 | 06:40 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Alright I've already done a search on this subject and I haven't really found what I'm looking for.
I ordered an LT1 kit made by TNT for my 88 GTA and I'm looking for a throttle cable extension bracket so I can hook up the spray plate. I was wondering if there was a part number for something like this out there.
Thanks for your help
Old May 10, 2004 | 09:38 PM
TexasLT1's Avatar
Car: '92 RS
It should have come with the kit, or you should be able to get it from TNT.
Old May 10, 2004 | 09:49 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
do the LT1 kits come with them even? the cables on a LT1 have enough ajustment I think, you will need to get one from NOS or make your own.
Old May 10, 2004 | 10:03 PM
TexasLT1's Avatar
Car: '92 RS
Thats what I was thinking after I posted it, but wasn't sure.
Old May 11, 2004 | 09:09 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its not very hard, ive made one before.
just get a piece of alum bar.. drill out the pattern to bolt it there, and countersink the screws... then drill the new pattern farther out.
i had it tapped and it worked fine for a few months, but when he took the bracket off and put it back on, he over-tightened the screws and the threads pulled from the alum.. he now has nuts behing the plate...
i know... totally worthless story. but i was bored.
Old May 11, 2004 | 02:54 PM
Car: 1988 GTA
Transmission: TH350
Does anyone know the part number for it from NOS
Old May 11, 2004 | 11:17 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
contact NOS tell them you lost yours or that you need one and you need a part # or something, thats what I would have to do. Tell them to look on the NOS-05151 part # kit parts list and find it for you. You can probably order it direct right then for the same price it will be special order from summit or jegs, etc
Old May 15, 2004 | 09:52 AM
Car: 1988 GTA
Transmission: TH350
Thanks alot, part number is NOS-17100 if anyone is ever wondering for future use. Cost $17 through Summit
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
