Superchargeing 305 H.O
Old May 12, 2004 | 04:38 AM
screamin_maro's Avatar
Ok i have a 84 Z28 with the stock 305 H.O L69 i want to put a roots type blower on it for the power and the wow factor i know most of you are going to start rambeling on about just get a 350 well i dont want one just yet. Well on to the question i think the CP ratio is 9.5.1 well with that said i think i will only be able to run
5 pounds of boots safely if i set the timeing right.I need to know how much boost will i acctually be able to put in it with out haveing my 305 blown in half thanks:lala:
Old May 12, 2004 | 05:45 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
pretty close to this:
https://www.thirdgen.org/techbb2/sho...hreadid=233325
Old May 12, 2004 | 10:55 PM
no because i think the motors have a differnet compression ratio all i want to know is how much boost i can run with out my 305 turning in to butter
Old May 15, 2004 | 12:50 PM
AFBCamaro's Avatar
Car: 1991 Camaro RS
Engine: Blown 355 Small Block
Transmission: They always break!
With that kind of compression you will be ok with no more than 6psi, total of 28 degress of total timing, and a fat tune.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
