Latest blower setup
Old Jun 12, 2004 | 07:13 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Latest blower setup
Just thought I'd pass along an updated look..
Old Jun 12, 2004 | 07:14 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Side..
Old Jun 13, 2004 | 05:53 AM
83 Crossfire TA's Avatar
Huh, no more TPI and I see a bunch of straps keeping the hose connections from blowing apart… anything else? Did it get the bigger engine yet? How does it run?
Old Jun 13, 2004 | 06:14 AM
nightrider87's Avatar
I thought you were going for dual LS1 TB before the blowers?
Old Jun 13, 2004 | 09:37 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Runs real good, still have a ton of tuning to do. I did take it for a good long drive from dayton to greenville. Other than blowing a collector gasket all to hell, everything held together. I replaced the gaskets with aluminum ones, so the leak is gone but the following day the fuel pump started showing signs of dying. I've ordered up a new Walbro 340... Of course the fuel tank is about 3/4 full. No track times yet.
I'm running a 92 305 TBI shortblock, LT1 cam, and L98 (64cc) heads. Yeah no more PITA TPI.. The HSR rocks for servicing.
The dual TB was more hassle than it was worth so I stuck with the single after the blowers.. I'm going to swap to a 3" GN type TB (Grumpy wants me to give it a try).
Right now working on getting the primer block sanded and ready for paint. Hopefully have it painted in the next couple weeks..
Old Jun 13, 2004 | 10:26 AM
About the fuel pump....
http://www.racetronix.com/Racetronix-TTA_Pump_Kit.html
Is this the kit I should be getting/the kit you're going to use?
I just want to double check that i'm not buying a pump with the incorrect physical dimensions.
Old Jun 13, 2004 | 10:37 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Actually I am building my own "hotwire" harness and getting a pump from..
http://www.fullthrottletech.com/foru...read.php?t=390
June special... $85 for pump and kit. BW
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
tmellott89
Oct 14, 2015 02:06 PM
88CamZ
Oct 8, 2015 10:29 AM
tattmann
Sep 27, 2015 05:20 PM
