Ran the Vortech TA finally, 13.854@103.83
Old Jun 26, 2004 | 11:57 PM
Guest
Guest
Posts: n/a
That was the best run of the day.
Best MPH, 104.02
Also ran a 13.856, let off for the 1-2 shift.
Best 60', 2.323
7-8psi, some knock here and there, bad traction, and a hot day. I let the car cool off between runs, but had no ice. Basically just testing the car out, making sure everything is working right. AFR's looked pretty decent. Next time out I'll have to have some suspension mods and probably run a little more pressure, like 10psi. The engine is a stock 91 305 (its in an 86 TA, running MAF), nothing has been done to it besides headers and the Vortech. Have some other little odds+ends of mods, but nothing of real significance.
Old Jun 27, 2004 | 10:47 AM
daverr's Avatar
not that bad of a run.are u running an automatic or manual???u also need to invest in some slicks.you`ll run better times
Old Jun 27, 2004 | 11:29 AM
conman962's Avatar
Car: 91 formula
Engine: 305 tpi
what type of vortech are u running
Old Jun 28, 2004 | 07:13 AM
Guido's Avatar
Car: 2000 Trans Am
Its an S-Trim compressor
Old Jul 5, 2004 | 04:12 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
vortech
keep backing up your timing until you get no knock or the motor will start rattling apart.. do you have a boost retard ignition???
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Antips16
Oct 30, 2015 06:42 PM
roysatikas
Sep 22, 2015 08:15 PM
earlpote
Sep 12, 2015 11:55 AM
