Carb nitrous plate orientation
Old Jul 9, 2004 | 09:24 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I know it matters that the plate be installed facing with the "up" arrow facing up, but does it matter if the fuel goes in from the front or the rear?Nitrous? This is on a plate system under a carb.
Old Jul 9, 2004 | 11:51 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Doesn't matter..I ran my plate both ways when I was trying to get it all plumbed to my liking...then sold it.Didn't make a difference in how it performed.
Old Jul 11, 2004 | 11:44 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the front to rear part doesnt matter but mounting the plate ubside down causes the nitrous which sprays downwards through the fuel into the intake ports will then spray upwards into the sides of the carburator venturies.
As you could imagine, air trying to get into the carb has to overcome the 1000 psi spraying the wrong direction.
as well as the carb's veturies which are looking for uniform airflow to deliver fuel now have to deal with a great turbulence.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
