What if....
Car: 1987 IROC-Z
What if....
What if I put a 150hp shot of nitrouse on my 200,000 mile 305ci T.P.I. motor??
It's a t5 tranny & has the L98 cam.
Who recommends a button and who recommends a microswitch? I preffer a button since I have no rev limiter and don't want to floor it when I miss a shift.
Just want to get some opinions, my prediction is 80-90 percent of people will tell me it's a gamble, but it's already on the car so..well...yea
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
kaboom:nono:
only unless you plan on getting a 350 soon.
I'm not sure which wil go first, the t5 or the 305.
I'm not sure which wil go first, the t5 or the 305. have an arming toggle switch
a full throttle switch
a window switch
You don't need, or don't even want a button to push when its nitrous time.
there's too much room for error if you put your nitrous on a button that you have to push with no safety check system.
a window switch
Car: 1987 IROC-Z
a window switch
a window switch
I have the micro switch and the toggle switch setup, but i need a window switch, where can I get the cheap one?
well the window switch just makes thing easier. you won't have to worry about hitting redline or spraying too soon
It activates when you are above X rpm but below Y rpm...i don't think they cost much at all. check around summitracing for one.
Car: 1988 Iroc-Z
If it does not blow the motor in seconds the tranny will come apart after not too much abuse. I say the engine will last longer than the tranny. It's all a matter of time though
Can't wait to hear the results of this!!!
Can't wait to hear the results of this!!! Trending Topics
Car: 1989 Iroc Z L98
Pull 6-8* of timing, run cold plugs and run a good race gas (100 octane should suffice) and I see it lasting a decent amount of time. I wouldnt put a lot of faith in that T-5 though.
Car: 1987 IROC-Z
everything is set now all I need is a fuel solenoid & it's on.
I have retarded my timing 6 degrees so I am running 0 degrees base instead of the stock 6 degrees advanced. I will also definatly be running colder plugs and I have a window switch that will turn the nitrous on @ 3,500 rpm & shut it off @ 5k allowing me to shift around 5,500 rpm.
I call it V8tec
should be pretty safe for a while but I'm pretty sure I take it down to a 100 shot so I can run it longer.
A video will come in due time.
I call it V8tec
should be pretty safe for a while but I'm pretty sure I take it down to a 100 shot so I can run it longer.A video will come in due time.
Car: 1987 IROC-Z
and this is why I never post anything anymore..
Can we have 1 ****ing thread where this **** doesn't get brought up. I have pmed him about something so drop it, it's knowone elses buisness but us if it's not much to ask lets stay on topic please.
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
No we cant let it go until YOU complete the deal. This has been going on for how long now? Too long. Do even bother to wonder WHY this is brought up in every thread? Because you did him wrong, we all know about it, and until he says otherwise that YOU made it right, we will continue to bring it up. Sorry if it bothers *you*, but imagine how he feels getting his money ripped off by some jerk whos posting on that same message board about stuff hes buying and mods hes doing. Its idiots like you who ruin the online buying experience and make all the honest people out there look bad.
We, as a community, have to stick together on this kind of stuff to make sure none of our online friends get ripped off. Regardless what forum its in, this will be brought up because YOU DID HIM WRONG AND WE WONT STOP UNTIL WE HAVE WORD FROM HIM THAT ITS FIXED.
