Turbo oil supply lines coming from oil temp sender hole
Old Jul 23, 2004 | 01:24 AM
280Z28's Avatar
I have a late-model (86+) block, and it has a hole above the oil filter that I believe is a temp sender hole that sees full pressure from the pump. My question: is that hole sitting BEFORE or AFTER the filter? If it's before, then I certainly plan to add an inline oil filter on the lines going to the turbos. So?
If it's post filter, then I'm set. I already managed to pull the plug out and have the fittings to run the lines.
Thanks,
Sam
Old Jul 23, 2004 | 05:11 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
This port is fed with full pressure, filtered oil from the main oil galley. It is often used for an oil pressure sending unit. This would be a good place to tap for turbo lubrication. I actually T'd my turbo lube lines offf of the oil pressure sending unit, which (on my 89 IROC-Z) is just above the oil filter. I didn't tap into the port behind the intake because that is a very tight area in the Camaro chassis. Maybe your Z has more room in that area.
You should post pics of your turbo system when your finished.. For some reason I have always been interested in american V8s in the Nissan Z cars. I am even more interested when a turbo is thrown in!
Old Jul 23, 2004 | 05:15 PM
89JYturbo's Avatar
I just reread your post. I see you are planning to use the same port I used (the one above the filter). I don't know why I thought you were talking about the one behind the intake. Anyway, as far as I know, that is post-filter. I hope so anyway, because I don't have an inline filter in my turbo lube lines! My turbos were happy for 5k miles so far.
Old Jul 23, 2004 | 07:50 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes it is
Attached Thumbnails Turbo oil supply lines coming from oil temp sender hole-scan-2-.jpg
Old Jul 23, 2004 | 08:05 PM
280Z28's Avatar
You guys answered my question 150%!
Thanks for the picture!!
Made my day for some reason.
Old Jul 24, 2004 | 08:48 AM
89JYturbo's Avatar
I wanted to post that pic too, I just couldn't find it anywhere. Thanks!
Old Jul 24, 2004 | 01:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here for those that saw it and were confused for a second (like me )
Old Jul 24, 2004 | 08:44 PM
nightrider87's Avatar
thanks b4c
Old Jul 24, 2004 | 09:40 PM
Engine: ls1, LB9
WOW! was it really that hard?
84z96L31vortec
Aug 20, 2017 12:16 AM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Elliswon
Aug 10, 2015 12:33 PM
