Which Crankshaft?
Old Jul 26, 2004 | 10:15 AM
Raiden's Avatar
Which Crankshaft for 10lbs of boost and a 125 shot of NOS?
I purchased a shortblock 3 years ago and put 12K on the engine as of this month. I have a paxton sn2000 on the unit also. Well, my luck, the snout on the end of the crank shaft broke I could not beleive it! I did not have that much tourqe on the shaftand after looking at the break, right behind the timming gear, it looks like there was a flaw in teh casting material.
Now I have to rebuild the engin again. My question is; Which forged material should I use? There is a very good local machine shop that has a chevy forged steel crank made of 1049 chevy steel. OR, I can purchase a brand new forged steel crank mad of 5140 for 100 bucks more off of ebay. I have a few concerns purchasing a crank off of ebay, then haveing some postal worker throwing the box around not knowing what is in the box........
Any thoughs or direction of what will work best for me?
I have AFR heads, 9psi boost, 50-75 NOS shot (have not used yet), tes headers/flowmaster exhaust. and pretty much anything else you can imagine.
Thank you for your help!
Old Jul 28, 2004 | 04:02 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
My only recomendations would be don't skimp or you are going to be doing the same thing you are doing now.
Old Jul 28, 2004 | 10:56 PM
Raiden's Avatar
I'm going wiht the 4340 peroid! I DO NOT want to do this again!
Old Jul 28, 2004 | 10:59 PM
92GTA's Avatar
Which crank are you buying? I've been watching this thread since it started since I'll be running a cog belt and 10+ pounds and I for damn sure do not want my snout breaking off like many here have had happen. When it comes to this $$$$$ is not a consideration IMO. I want to buy what is flat out the absolute strongest crank made for a SBC...
Old Jul 29, 2004 | 12:06 AM
Raiden's Avatar
I'm going with the Eagle 4340. Now, you can purchase one of the billet crankshafts, but they are very expensive!
Old Jul 29, 2004 | 07:34 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
the eagle 4340 cranks can handle 1k plus horse. I am going with one of them for my car.
Old Jul 29, 2004 | 11:28 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I'm using an Eagle 4340.I read somewhere they have been tested at 1200hp with no problems,plus they are very reasonably priced.
Old Jul 29, 2004 | 11:37 AM
biggtime's Avatar
I run the eagle 4340 and so does blownss
Old Jul 29, 2004 | 11:48 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
What are the cast eagle cranks good to?? I have one and I want a procharger next year....would it be OK for say 6psi??
Sorry for swithching the subject, but I can't find much info on their cast cranks anywhere.
Old Jul 29, 2004 | 02:50 PM
biggtime's Avatar
put the good crank in and forget the blower if you can't afford to do it right.
Old Jul 29, 2004 | 03:15 PM
Car: '92 RS Camaro
Transmission: TH400
That's what I thought,If you can afford a 4 grand blower set-up then a $400 crank is hardly in the equation.
Old Jul 29, 2004 | 09:48 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i had the same problem broke the stock crank behind the timing spocket put a forged crank in broke it,problem was supercharger belt i had to tight. have cast one in for two years still working belt alittle looser now.
Old Jul 30, 2004 | 07:55 AM
Car: 91Z
I guess I will change the crank at that time, thanks guys.
Old Jul 30, 2004 | 02:21 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i have had the same callies crank in my 388 for the past 3 years with no probs
Old Jul 30, 2004 | 04:47 PM
biggtime's Avatar
With a supercharger? I thought your sig had a turbo on it.
Old Jul 30, 2004 | 05:45 PM
i dont think i said i had a supercharger did i?
Old Jul 30, 2004 | 05:49 PM
but on my wifeys car i have had a stock ls1 crank in it for two years of daily driving with a vortec on it with 10-12 lbs of boost no problems so i dont know, it sounds like this crank shaft had a flaw from the factory,also i forgot but did anybody check the har. balancer to make sure it is in balance. i have had a couple crank snouts tore up by that issue before
Old Jul 30, 2004 | 09:40 PM
AC's Avatar
AC
Car: Used to drive a camaro
Raiden, I'm in the process of building a balanced forged 383 motor using Eagles components. 4340 crank, 3DH-beam rods and JE forged -16cc pistons. With the heads I'm using (hopefully Santa brings me my AFR's) and the 14# pulley I ordered I'll make 550+ rwhp. I was d*mn near convinced by summit and eagle's techs that the components I bought wouldn't even break a sweat @ 6000 rpms.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
LT1Formula
Aug 20, 2015 09:36 PM
